05-18-2017, 06:19 | #21 (permalink) |
Junior Member Join Date: Nov 2014 Location: dhaka,bangladesh Age: 30
Member: 2292325 Status: Offline Thanks Meter: 11 | UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. Operation: Reset FRP Selected model: SM-J710F Software version: 28.2 Waiting ADB device... Ok Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZKDINS Phone version: J710FXXU2APK6 PDA version: J710FXXU2APK6 CSC version: J710FODD2APK6 CSC country code: India CSC sales code: INS HW version: MP 0.300 Phone SN: RF8H90FG6GZ Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2016-11-01 RF cal date: 20160906 IMEI: Bypass FRP... Ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.2 adb file https://drive.google.com/file/d/0B_N...RpNmJSSGM/view |
The Following 5 Users Say Thank You to nishubd For This Useful Post: |
10-22-2017, 20:34 | #22 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2125426 Status: Offline Thanks Meter: 27 | J710F REset frp Done Don't waste your time with Combination Files. just USE Z3X and choose model N920P and not J710F. Make reset FRP in Download Mode. after that make Factory RESET and ENJOY |
The Following 4 Users Say Thank You to guynirina For This Useful Post: |
11-03-2017, 15:25 | #23 (permalink) |
Freak Poster Join Date: Feb 2010 Location: sharjha
Member: 1236922 Status: Offline Sonork: sajer007 Thanks Meter: 101 | UMT BOX android 7 No downgrade NO combination Device: SM-G610F Operation: Reset FRP Searching for Device... Found Model: SM-J710F Baseband: J710FXXU3BQH2 Bootloader: J710FXXU3BQI8 PDA: J710FXXU3BQI8 Android Version: 7.0 Resetting FRP Lock... Done ---------------- IMPORTANT ---------------- Accept Agreement on phone to enter Home Screen. Goto Menu > Settings > Backup and Reset > Factory data reset. Operation Finished. Elapsed Time: 00:08 [Ultimate Samsung Flasher v1.3] |
The Following User Says Thank You to sajer007 For This Useful Post: |
11-21-2017, 12:23 | #24 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: INDIA-uttranchal-rishikesh Age: 47
Member: 484665 Status: Offline Sonork: 100.1578012 Thanks Meter: 175 | Quote:
how do i try but not success | |
03-08-2018, 07:10 | #26 (permalink) | |
Freak Poster Join Date: Jan 2009
Member: 956406 Status: Offline Thanks Meter: 55 | J710F frp NO solution Quote: Many thanks in advance for your help ! | |
