Old 06-13-2018, 23:17   #91 (permalink)
eyasin's Avatar
Member: 885387
Sonork: 100.1597540
Thanks Meter: 82
I have full solution
And I done many pics
Max 5 min work
Old 06-14-2018, 04:19   #92 (permalink)
Blocked
Member: 162707
Thanks Meter: 66
Max 5 min work
hello what is the solution please
Old 06-19-2018, 23:48   #93 (permalink)
Member: 2179862
Thanks Meter: 17
No luck reading SPC after flash CombFile throug Z3X.
Writing AT RIL... OK
Initialization AT RIL... error (2)
Done with Samsung Tool PRO v.32.7
Any suggestion?
Old 06-21-2018, 21:05   #94 (permalink)
Member: 679135
Sonork: 100.1606448
Thanks Meter: 436
Sm-J727P help for unlock
read info
Searching Samsung modem... detected COM53
Reading phone info...
Model: SM-J727P
AP version: J727PVPU3ARC2
CSC version: J727PSPT3ARC2
CP version: J727PVPU3ARC2
Product code: XAS
Phone SN: 00000000000
IMEI: 353559080580028/35355908058002
Unique number: CQ3004DF2FC1224
Reading IMEI... OK
Done with Samsung Tool PRO v.32.2
unlock process
Waiting ADB device... OK
Model: SM-J727P
Android version: 7.0
PDA version: J727PVPU3ARC2
Phone version: J727PVPU3ARC2
Product code: Not Active
CSC country code: USA
CSC sales code: XAS
HW version: J727P.02
RF cal date: 2017.03.18
Chip name: MSM8953
Modem board: MSM8953
Security patch: 2018-03-01
Boot Warranty bit: 1
Initialization AT RIL... root required
Checking Super user right... true
Initialization AT RIL... OK
Unlocking... error
any idea pleases?
Old 06-21-2018, 21:45   #95 (permalink)
Member: 2730595
Thanks Meter: 13
downgrade ,then do unlock
Old 06-21-2018, 22:18   #96 (permalink)
Member: 679135
Sonork: 100.1606448
Thanks Meter: 436
what version do you recommend?
Old 06-22-2018, 03:51   #97 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
Any suggestion?
http://forum.gsmhosting.com/vbb/13115680-post33.html
Old 06-23-2018, 20:18   #98 (permalink)
Member: 1693475
Thanks Meter: 12
Initialization at RIL... error (2)
In Z3x, while trying to read MSL in step 2 below, Z3X errors out and says 'Initialization at RIL... error (2). What's wrong ?
________________
Originally Posted by GalaxyVibe View Post
Better explained by "larez":
1. First we passed the binary combination 3
2. We read the MSL or SPC with z3x or optopus using the model j320p or g900p only in opotpus in z3x read it by its normal model
3. Then we pass the binary software 3 ql3 to be in the latest version, then in the call menu we dial ## 3424 # and put the msl we go usb senting then we select dm-moden-adb and save the configuration
4. Now we activate a serail port we search in device administrator to see what port number is with the NV Item we open it and look for the port number of the serial port and connect then we go to the writer option and pass the NVRAM and restart the cell phone and BOOM will be Unlock
Files needed
https://drive.google.com/file/d/1p2Q...U_E1IPd1Z/view
password= furqanwali
___________
Old 06-24-2018, 03:49   #99 (permalink)
chezral's Avatar
Member: 203715
Thanks Meter: 227
Thx for help guys. Here are my slightly different steps:
1- flash this file for root : Samsung J7 Perx J727P Nougat 7.0 Tested Root File | Samsung FRP
2- install superSU apk
3- install idone/GT v3.15 apk (had found it on this forum a while ago)
4- open GT app and scroll done and click 'IOTHIDDENMENU'
5- select usb settings
6- select DM+MODEM+ADB
7- open Z3X select J727p and select unlock, this show [Initialization at RIL... error]
8- use NV tool from this post to write nv, this show successful, but also shows write nv failed.
9- restart the phone and now it's unlocked!
So you just need to root and use GalaxyTools 3.15 to enable diag, then unlock. Not sure if Z3X or the nv is what did the unlock, you can try one and see which does the unlock, but despite error phone will be unlocked!
combo not needed or msl.
Old 06-25-2018, 00:00   #100 (permalink)
Member: 1693475
Thanks Meter: 12
I'm trying your solution however I get 'SW DV CHECK FAIL about FUSED 3 > Binary." on Odin when attempting the root flash. To verify, my baseband is J727PVPU3ARC2
Old 07-04-2018, 16:06   #101 (permalink)
Member: 220595
Thanks Meter: 355
SO, any way to unlock by writing NV file?
Old 07-18-2018, 19:29   #102 (permalink)
Member: 1511023
Thanks Meter: 4
Pues pude desbloquear el mio sin Necesidad del MSL, Sin Root, Sin comandos. Tengo la Z3x y solo la use para flashear los archivos.
Voy a Ver lo mejor que puedo resumir lo que hice.
1.- Flashe el archivo combination .......U3ARA1 (Lo descargue de la Z3X)
2.- Una vez que subio. Le dimos donde dice IMEI. En este teclado escribi el comando *#0808#
se abre el menú activan dm-modem-adb y se activa el puerto. Buscamos el puerto. (supongo todos saben como buscar el puerto). Abrimos el programa NV Items. a) Seleccionamos puerto. b)Le dimos a conectar (Connect) c) despues le dimos a Read (Leer informacion del telefono), d) Por ultimo le dimos a escribir (Write). Seleccionamos el archivo J727p nv.
Una vez que termino de escribir le dimos donde dice Mode- Reset.
El telefono se reinicio y subio con señal. Zaaaaaaaaz
Por ultimo pase el software oficial que tenia anteriormente el de 4 archivos y el telefono siguio con señal.
Puse los apn y tiene señal y data.
The Following User Says Thank You to rmelo2010 For This Useful Post:
Old 07-25-2018, 09:12   #103 (permalink)
Member: 1872263
Thanks Meter: 3
I have the same problem. any way to downgrade the phone?
Old 08-01-2018, 21:46   #104 (permalink)
Member: 2744195
Thanks Meter: 4
Hey! guys I need a help here. I tried combination on my J727P and then when i use the NV-items_reader_writer to write the J727P file it says ''failed Phone does not answer'' ??
Old 08-02-2018, 18:55   #105 (permalink)
Member: 2802156
Thanks Meter: 173
You need to select correct Diag port, look in device manager for port number
on phone need to have DM + MODEM/ACM + ADB selected
Page generated in 0.20905 seconds with 8 queries
