06-21-2018, 21:05 | #94 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | Sm-J727P help for unlock read info Code: Searching Samsung modem... detected COM53 Reading phone info... Model: SM-J727P AP version: J727PVPU3ARC2 CSC version: J727PSPT3ARC2 CP version: J727PVPU3ARC2 Product code: XAS Phone SN: 00000000000 IMEI: 353559080580028/35355908058002 Unique number: CQ3004DF2FC1224 Reading IMEI... OK IMEI: 353559080580028 Done with Samsung Tool PRO v.32.2 Code: Waiting ADB device... OK Reading phone info... Model: SM-J727P Android version: 7.0 PDA version: J727PVPU3ARC2 CSC version: J727PSPT3ARC2 Phone version: J727PVPU3ARC2 Product code: Not Active CSC country code: USA CSC sales code: XAS Phone SN: 00000000000 IMEI: 353559080580028 HW version: J727P.02 RF cal date: 2017.03.18 Chip name: MSM8953 Modem board: MSM8953 Security patch: 2018-03-01 Boot Warranty bit: 1 Writing AT RIL... OK Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... OK Unlocking... error Done with Samsung Tool PRO v.32.2 |
06-22-2018, 03:51 | #97 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Quote:
http://forum.gsmhosting.com/vbb/13115680-post33.html | |
06-23-2018, 20:18 | #98 (permalink) |
Freak Poster Join Date: Nov 2011 Location: Dallas, Texas, USA
Member: 1693475 Status: Offline Thanks Meter: 12 | Initialization at RIL... error (2) In Z3x, while trying to read MSL in step 2 below, Z3X errors out and says 'Initialization at RIL... error (2). What's wrong ? ________________ Originally Posted by GalaxyVibe View Post Better explained by "larez": 1. First we passed the binary combination 3 2. We read the MSL or SPC with z3x or optopus using the model j320p or g900p only in opotpus in z3x read it by its normal model 3. Then we pass the binary software 3 ql3 to be in the latest version, then in the call menu we dial ## 3424 # and put the msl we go usb senting then we select dm-moden-adb and save the configuration 4. Now we activate a serail port we search in device administrator to see what port number is with the NV Item we open it and look for the port number of the serial port and connect then we go to the writer option and pass the NVRAM and restart the cell phone and BOOM will be Unlock Files needed https://drive.google.com/file/d/1p2Q...U_E1IPd1Z/view password= furqanwali ___________ |
06-24-2018, 03:49 | #99 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Bim
Member: 203715 Status: Offline Thanks Meter: 227 | Thx for help guys. Here are my slightly different steps: 1- flash this file for root : Samsung J7 Perx J727P Nougat 7.0 Tested Root File | Samsung FRP 2- install superSU apk 3- install idone/GT v3.15 apk (had found it on this forum a while ago) 4- open GT app and scroll done and click 'IOTHIDDENMENU' 5- select usb settings 6- select DM+MODEM+ADB 7- open Z3X select J727p and select unlock, this show [Initialization at RIL... error] 8- use NV tool from this post to write nv, this show successful, but also shows write nv failed. 9- restart the phone and now it's unlocked! So you just need to root and use GalaxyTools 3.15 to enable diag, then unlock. Not sure if Z3X or the nv is what did the unlock, you can try one and see which does the unlock, but despite error phone will be unlocked! combo not needed or msl. |
06-25-2018, 00:00 | #100 (permalink) |
Member: 1693475 Status: Offline Thanks Meter: 12 | I'm trying your solution however I get 'SW DV CHECK FAIL about FUSED 3 > Binary." on Odin when attempting the root flash. To verify, my baseband is J727PVPU3ARC2 |
07-18-2018, 19:29 | #102 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1511023 Status: Offline Thanks Meter: 4 | Pues pude desbloquear el mio sin Necesidad del MSL, Sin Root, Sin comandos. Tengo la Z3x y solo la use para flashear los archivos. Voy a Ver lo mejor que puedo resumir lo que hice. 1.- Flashe el archivo combination .......U3ARA1 (Lo descargue de la Z3X) 2.- Una vez que subio. Le dimos donde dice IMEI. En este teclado escribi el comando *#0808# se abre el menú activan dm-modem-adb y se activa el puerto. Buscamos el puerto. (supongo todos saben como buscar el puerto). Abrimos el programa NV Items. a) Seleccionamos puerto. b)Le dimos a conectar (Connect) c) despues le dimos a Read (Leer informacion del telefono), d) Por ultimo le dimos a escribir (Write). Seleccionamos el archivo J727p nv. Una vez que termino de escribir le dimos donde dice Mode- Reset. El telefono se reinicio y subio con señal. Zaaaaaaaaz Por ultimo pase el software oficial que tenia anteriormente el de 4 archivos y el telefono siguio con señal. Puse los apn y tiene señal y data. |
The Following User Says Thank You to rmelo2010 For This Useful Post: |
08-01-2018, 21:46 | #104 (permalink) |
Junior Member Join Date: Aug 2017
Member: 2744195 Status: Offline Thanks Meter: 4 | Hey! guys I need a help here. I tried combination on my J727P and then when i use the NV-items_reader_writer to write the J727P file it says ''failed Phone does not answer'' ?? |
08-02-2018, 18:55 | #105 (permalink) | |
No Life Poster Join Date: Jan 2018
Member: 2802156 Status: Offline Thanks Meter: 173 | Quote:
on phone need to have DM + MODEM/ACM + ADB selected | |
