07-14-2018, 14:11 | #1 (permalink) |
Freak Poster Join Date: Mar 2016 Location: punjab ,india
Member: 2548878 Status: Offline Thanks Meter: 97 | SM-J727T unlocking error ? Selected model: SM-J727T Software version: 33.2 Checking Login and Password... OK Ballance: 33 crd. You have 33 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J727T Android version: 7.0 PDA version: J727TUVS3ARC1 CSC version: J727TTMB3ARC1 Phone version: J727TUVS3ARC1 Product code: SM2J727TZDATMB CSC country code: USA CSC sales code: TMB Phone SN: R28K41TMVHR IMEI: 355619087*** HW version: REV0.7 RF cal date: 20180418 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2018-03-01 Boot Warranty bit: 0 Searching Samsung diag port... detected COM17 Reading phone info... OK CP version: J727TUVS3ARC1 CP build: Mar 5 2018 19:31:23 Reading data from phone... error (1) Done with Samsung Tool PRO v.33.2 |
07-14-2018, 18:22 | #2 (permalink) |
No Life Poster Join Date: Jan 2018
Member: 2802156 Status: Offline Thanks Meter: 173 | try again after factory reset, open unlock app > perm unlock - make sure you get message that device not eligble for unlocking through app if still fail after this, flash eng modem If uart is available to you, then you do not have to unlock this model by credits (use search in this and other sections, solution is out there, same as for s337tl) |
The Following User Says Thank You to gsm_service4u For This Useful Post: |
07-15-2018, 20:44 | #3 (permalink) | |
Freak Poster Join Date: Nov 2003 Location: At The Shop
Member: 43098 Status: Offline Thanks Meter: 71 | Quote:
The Following User Says Thank You to Knowledge For This Useful Post: |
08-05-2018, 23:36 | #4 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Philippines
Member: 379023 Status: Offline Thanks Meter: 38 | flash the modem using this... https://www.4shared.com/rar/ooVoj3QM...U3ARA1tar.html then try to unlock again..its working to me..we got the same problem at first... FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Unlock Selected model: SM-J727T1 Software version: 33.5 Checking Login and Password... OK Ballance: 35 crd. You have 35 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J727T1 Android version: 7.0 PDA version: J727T1UVS3ARE1 CSC version: J727T1TMK3ARE1 Phone version: J727TUVU3ARA1 Product code: SM2J727TZKETMK CSC country code: USA CSC sales code: TMK Phone SN: R28K4023WLD IMEI: 354254094466997 HW version: REV0.7 RF cal date: 20180403 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2018-05-01 Boot Warranty bit: 0 Searching Samsung diag port... detected COM138 Reading phone info... OK CP version: J727TUVU3ARA1 CP build: Jan 24 2018 13:02:34 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.33.5 |
The Following 4 Users Say Thank You to mysterious guy For This Useful Post: |
