04-13-2017, 13:24 | #1 (permalink) |
Junior Member Join Date: Mar 2017 Location: Old MTv
Member: 2700251 Status: Offline Thanks Meter: 9 | sm-n900 repair imei error ssnv not found log: BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-N900 Software version: 28.0 Checking CERT file... Ok KEY ID: 0813 Waiting ADB device... Ok Reading phone info... Model: SM-N900 Android version: 5.0 Product code: Phone version: PDA version: N900XXUEBNL8 CSC version: N900OXAEBNL8 CSC country code: Poland CSC sales code: XEO HW version: Phone SN: Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking magic... SSNV not found Done with Samsung Tool PRO v.28.0 |
The Following User Says Thank You to beaviz For This Useful Post: |
04-13-2017, 13:27 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
IMEI NOT EXIST how you want repair not existed thing!!!???? | |
The Following User Says Thank You to blang For This Useful Post: |
04-13-2017, 14:22 | #3 (permalink) |
Member: 2700251 Status: Offline Thanks Meter: 9 | Explain me Thanks mr.blang,...but what you mean not working modem ?? is the modem hardware broken or what it can do? can you explain me more ???? thanks.....again Last edited by beaviz; 04-13-2017 at 14:28. |
