10-06-2018, 20:12 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 220 | SM-N910f unlock fail-help needed [Answered] THE NETWORK WORKING ONLY FOR LYCA SIM ..REST ALL NETWORK SHOWING ERROR -NETWORK NOT REGISTERED UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC' (ignore it, if it's not available). 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-N910F Selected port: COM91 SAMSUNG Mobile USB Serial Port Software version: 33.8 Reading phone info... Reading IMEI... OK IMEI: 356900067067323 Unlocking... error (02) Done with Samsung Tool PRO v.33.8 |
10-06-2018, 20:56 | #2 (permalink) |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Flash this modem then retry https://drive.google.com/open?id=0Bz...TgzMWs3VDNlUVU |
10-09-2018, 01:22 | #3 (permalink) |
Member: 216446 Status: Offline Thanks Meter: 220 | Still same problem I FLASHED THE FILE BUT THE PHONE GOT BRICKED SO I FLASHED WITH THE FIRMWARE ...PHONE GOT ON DATA IS WORKING ONLY CALL /NETWORK NOT SHOWING SHOWING ERROR NOT REGISTERED ON NETWORK TRIED TO SELECT NETWORK MANUALLY ASWELL AS AUTOMATICALY MANUAALY SELECTED SHOWING SELECTED NETWORK UNAVAILABLE IF I UNLOCK UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC' (ignore it, if it's not available). 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-N910F Selected port: COM91 SAMSUNG Mobile USB Serial Port Software version: 33.8 Reading phone info... Reading IMEI... OK IMEI: 356900067067323 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.33.8 PLEASE NOTE ONE NETWORK LYCA NETWORK IS WORKING NO OTHER NETWORK WORKING |
10-10-2018, 01:55 | #4 (permalink) |
Member: 216446 Status: Offline Thanks Meter: 220 | No its not working again N910f network not registered error-help please i flashed the error was there so i tried to reset efs cfauto root done-drk reset error came but phone got on write cert done operation failed -phone not rooted qcn written sucess now imei showing /01 sn is not shown please help there is no option to repair imei how to fix my imei n sn and get network working |
