Old 10-28-2017, 16:48   #1 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,645
Thumbs up Sm-t377w unlock only downgrade modem [Solution inside]
UNLOCK INSTRUCTIONS:
To unlock NEW security type:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
To unlock OLD security type:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
To read security codes (all security types):
4. Press 'Read codes' button to read security codes.
To reset Google account activation or Samsung reactivation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Unlock
Selected model: SM-J120W
Software version: 29.2
Searching Samsung modem... detected COM711
Reading phone info... OK
Model: SM-T377W
AP version: T377WVLU2API2
CSC version: T377WOYA2API2
CP version: T377WVLU2API1
Product code: SM-T377WZKAXAC
Phone SN: R52HA1J2E5M
Unique number: CAJ030D47438BA3
Reading IMEI... OK
IMEI: 358510070603572 (SIGN: OK)
Reading data from phone... OK
Unlocking... OK
Rebooting phone... OK
Unlock done
Done with Samsung Tool PRO v.29.2
The Following User Says Thank You to ghacks For This Useful Post:
Old 09-20-2019, 12:27   #2 (permalink)
mdalamgir's Avatar
Member: 694638
Sonork: no
Thanks Meter: 164
Operation: Unlock
Model: SM-T377W
Reading IMEI... OK
Unlocking... OK
Unlock done
Please uplod downgrade modem
Thanks
Old 01-14-2021, 20:49   #3 (permalink)
Member: 1608526
Sonork: 100.1611913
Thanks Meter: 60
Thanks
https://boxwares.net/af0a3ef48cc18a6...xWares.tar.md5
The Following User Says Thank You to otchere For This Useful Post:
Page generated in 0.14100 seconds with 8 queries
