softbank 731... [Solved] I need original firmware for 731sc... thanks. |
http://forum.gsmhosting.com/vbb/show...89&postcount=1 you should ask other section or buy z3x box:) |
if you dont upgrade your card yet then reinstall old qt5.6.42 recommended is upgrade your card and use latest qt tool:) andy_jpn |
READ NEWS FOR DETAILS! Searching Samsung USB interface... not found Searching Qualcomm USB interface... not found Searching phone at COM interface... ok Model: 731SC SW: 731SCIG1 Flash patched FW from support I flashing with same firmware but same result. |
I flashing same firmware still no luck and I try flash with 731SCID2 get result: READ NEWS FOR DETAILS! Checking ports... ok Searching Samsung USB Flash interface... detected (COM11) Sending file 1 of 4... bad answer |
check verion inside phone , compare with patch and flash needed file. thats all. |
just click read info...you should read sw version... |
post result... |
b.r. |
please read carefully....after flash with 731SCIG1_unlock_media_and_network_patch.crp you dont need to direct unlock your phone...your job is done when you finished flash with it...can you just try insert other sim and post here if it doesnt recognize it...:eek: |
