05-11-2021, 10:28 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | t805 imei null [Answered] Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. Operation: Reset EFS Selected model: SM-T805 Software version: 42.11 Waiting ADB device... OK Reading phone info... Model: SM-T805 Android version: 6.0.1 PDA version: T805XXU1CPI3 CSC version: T805OJV1CPI2 Phone version: Product code: CSC country code: IRAN CSC sales code: THR Phone SN: R52G40PADHM IMEI: HW version: RF cal date: Chip name: EXYNOS5420 Modem board: Security patch: 2016-09-01 Boot Warranty bit: 1 Checking Super user right... true Backuping EFS... OK Reseting EFS... OK Rebooting phone... OK Done with Samsung Tool PRO v.42.11 |
05-11-2021, 10:31 | #2 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-T805 Software version: 42.11 Checking CERT file... OK KEY ID: 0749 Waiting ADB device... OK Reading phone info... Model: SM-T805 Android version: 6.0.1 PDA version: T805XXU1CPI3 CSC version: T805OJV1CPI2 Phone version: Product code: CSC country code: IRAN CSC sales code: THR Phone SN: IMEI: HW version: RF cal date: Chip name: EXYNOS5420 Modem board: Security patch: 2016-09-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking magic... SSNV not found Done with Samsung Tool PRO v.42.11 |
05-12-2021, 01:06 | #6 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: ARG - AZUL
Member: 226845 Status: Offline Thanks Meter: 78 | Quote:
R | |
