01-21-2015, 16:18 | #2 (permalink) |
Freak Poster Join Date: Mar 2014 Location: United States
Member: 2146046 Status: Offline Thanks Meter: 62 | To fix this, Use Z3X "REPAIR" Option (Red Wrench) Make sure to check "Disable Test Mode" (this will get rid of Factory Mode aka "TEST MODE" on your screen). Also Check IMEI and fill in IMEI for your device to repair IMEI. |
The Following User Says Thank You to GTrader For This Useful Post: |
01-21-2015, 17:01 | #3 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: THREE STARS AND A SUN
Member: 1208596 Status: Offline Thanks Meter: 23 | Quote:
phone status now blink for 2-3 sec then OFF after rooting flash rootfile at odin.. now blink then off.. but still have download mode.. thanks | |
01-21-2015, 18:00 | #4 (permalink) |
Member: 2146046 Status: Offline Thanks Meter: 62 | Reflashing the firmware will not get rid of Factory mode which is displayed on your screen. You need to use Z3X Repair Option and check "Disable Test Mode" then click OK and let Z3X disable it. You can also manually do it by using some kind of file explorer for your phone. Youtube "How to Disble Factory Mode" |
01-22-2015, 02:26 | #6 (permalink) |
Crazy Poster Join Date: May 2007 Location: philippines
Member: 516428 Status: Offline Sonork: 100.1658202:loveulabs Thanks Meter: 6 | i already encounter this situation what i did go to "REPAIR" then check "disable test mode" but select the I9300 model because when you choose T999v the REPAIR OPTION is disable...and to repair for the IMEI just use T999v model and make it sure your phone is rooted... |
01-22-2015, 04:00 | #7 (permalink) | |
please share root file.. phone still same error after flashing.. but when i flash root at odin.. after flash blink then off for 2-3 secs | |
