U880 unlock problem. Pls help! v.1.3.3 supported models: 53 andrew_tm 2008(c) ;) Mode: Normal Model: U880 Build version: Feb 20 200609:02:49JUL 3 2005 SW Version: U880-MSM6250-V10b_wm-FEB-08-2006-H3G-DU IMEI: 35705000431193-6 BlueTooth Address: 00:12:56:CC:69:41 Elapsed: 0 secs. Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM130 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... !!! Exception !!! [WriteFile function failed (win error code: 31)] EComPort How i can solve problem? Help me pls! |
SECOND: READ MANUAL BEFORE USE SOFTWARE U300, U310, U890, U880, U450, U900 Step by step manual: 1. Download needed firmware for your phone from folder "SPECIAL_FW_FOR_UNLOCK_U300_U310_U450_U880_U89 0_U9 00" from support area. 2. Flash phone. 3. Press unlock button. 4. If phone will show "no network" write NVM (c:\programm files\z3x\lg\lgq\nvm\) P.S. All firmware in SPECIAL_FW_FOR_UNLOCK_U300_U310_U450_U880_U890_U90 0 folder support 32Kb, 64Kb, 128Kb sim card |
Thanks for fast reply. But i flashed phone with special firmware on support then and i tried use soft 1.3.4 but problem not solve. Maybe cable problem? |
From your log i see not special firmware inside phone. Special firmware U880_V10B-FEB-08-2006-H3G-IT.crp in your log: SW Version: U880-MSM6250-V10b_wm-FEB-08-2006-H3G-DU |
Check cable, drivers... -- andrew_tm 2009 :) |
Here is the log sir! v.1.3.4 supported models: 53 andrew_tm 2008(c) ;) Mode: Normal Model: U880 Build version: Feb 20 200609:02:49JUL 3 2005 SW Version: U880-MSM6250-V10b_wm-FEB-08-2006-H3G-DU IMEI: 35705000431193-6 BlueTooth Address: 00:12:56:CC:69:41 Elapsed: 0 secs. Mode: Normal Model: U880 Build version: Feb 20 200609:02:49JUL 3 2005 SW Version: U880-MSM6250-V10b_wm-FEB-08-2006-H3G-DU IMEI: 35705000431193-6 BlueTooth Address: 00:12:56:CC:69:41 Elapsed: 0 secs. Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM81 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... !!! Exception !!! [WriteFile function failed (win error code: 31)] EComPort I tried on another USB cable and reinstall driver but not solve this problem. How should i do? |
Computer detect phone in com82 but in this state:"Select modem comport: Com81" Is problem in there? Thanks for reply! |
Reflash phone again, press unlock :) -- andrew_tm 2009 :) |
hm,if you flash him with file from support for unlock to work with all sim and nvm u880 ok network it must work(drivers and cable is ok i gess and you use moto test when program said to you to do) today i done 3 pcs 2 are 11c and 1 is 10a all 3 working with all sim |
-------------------------------------------------------------------------------- hi hello plz help me i need lg u880 nvm file. I m search on support side but not found. Thank's |
...\Z3X\LG\LGQ\NVM\U880_network_ok.cnv or http://z3x-team.com/?module=flashdown -> 13. LG NVM -> U880_network_ok.cnv -- andrew_tm 2009 :) |
