03-10-2009, 10:42 | #1 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 679545 Status: Offline Thanks Meter: 10 | U880 unlock problem. Pls help! supported models: 53 andrew_tm 2008(c) Mode: Normal Model: U880 Build version: Feb 20 200609:02:49JUL 3 2005 SW Version: U880-MSM6250-V10b_wm-FEB-08-2006-H3G-DU IMEI: 35705000431193-6 BlueTooth Address: 00:12:56:CC:69:41 Elapsed: 0 secs. Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM130 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... !!! Exception !!! [WriteFile function failed (win error code: 31)] EComPort How i can solve problem? Help me pls! |
03-10-2009, 11:38 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,579 | Quote:
SECOND: READ MANUAL BEFORE USE SOFTWARE U300, U310, U890, U880, U450, U900 Step by step manual: 1. Download needed firmware for your phone from folder "SPECIAL_FW_FOR_UNLOCK_U300_U310_U450_U880_U89 0_U9 00" from support area. 2. Flash phone. 3. Press unlock button. 4. If phone will show "no network" write NVM (c:\programm files\z3x\lg\lgq\nvm\) P.S. All firmware in SPECIAL_FW_FOR_UNLOCK_U300_U310_U450_U880_U890_U90 0 folder support 32Kb, 64Kb, 128Kb sim card | |
03-10-2009, 12:25 | #5 (permalink) | |
From your log i see not special firmware inside phone. Special firmware U880_V10B-FEB-08-2006-H3G-IT.crp in your log: SW Version: U880-MSM6250-V10b_wm-FEB-08-2006-H3G-DU | |
03-10-2009, 13:10 | #7 (permalink) |
Member: 679545 Status: Offline Thanks Meter: 10 | Here is the log sir! v.1.3.4 supported models: 53 andrew_tm 2008(c) Mode: Normal Model: U880 Build version: Feb 20 200609:02:49JUL 3 2005 SW Version: U880-MSM6250-V10b_wm-FEB-08-2006-H3G-DU IMEI: 35705000431193-6 BlueTooth Address: 00:12:56:CC:69:41 Elapsed: 0 secs. Mode: Normal Model: U880 Build version: Feb 20 200609:02:49JUL 3 2005 SW Version: U880-MSM6250-V10b_wm-FEB-08-2006-H3G-DU IMEI: 35705000431193-6 BlueTooth Address: 00:12:56:CC:69:41 Elapsed: 0 secs. Start Unlock... - Unlock stage #1... - Write data... - Phone reboot! - Select Modem Port:COM81 - Unlock stage #2... - Unlock stage #3... - Unlock stage #4... - Start read nand... - Read nand done... - Start erase nand... - Erase done... - Start write nand... !!! Exception !!! [WriteFile function failed (win error code: 31)] EComPort I tried on another USB cable and reinstall driver but not solve this problem. How should i do? |
03-10-2009, 16:42 | #10 (permalink) |
Freak Poster Join Date: May 2007 Location: Mladenovac-Belgrade Serbia
Member: 503664 Status: Offline Thanks Meter: 61 | hm,if you flash him with file from support for unlock to work with all sim and nvm u880 ok network it must work(drivers and cable is ok i gess and you use moto test when program said to you to do) today i done 3 pcs 2 are 11c and 1 is 10a all 3 working with all sim |
The Following User Says Thank You to johnnyml For This Useful Post: |
04-23-2009, 20:58 | #11 (permalink) |
Junior Member Join Date: Jul 2004 Age: 52
Member: 73413 Status: Offline Thanks Meter: 2 | -------------------------------------------------------------------------------- hi hello plz help me i need lg u880 nvm file. I m search on support side but not found. Thank's |
04-23-2009, 21:44 | #12 (permalink) |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | ...\Z3X\LG\LGQ\NVM\U880_network_ok.cnv or http://z3x-team.com/?module=flashdown -> 13. LG NVM -> U880_network_ok.cnv -- andrew_tm 2009 |
u880 unlock problem pl help me | ruvanw1979 | FuriousGold | 5 | 08-28-2007 04:19 |
6310i ver 5.22 unlock problem ... pls help ... | alianu | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 06-17-2003 20:55 |
GD 55 Unlock Problem - PLS Help | Synchro | Panasonic | 0 | 05-14-2003 07:25 |
Geo@i mt345 unlock problems....pls help | PTR999 | Mitsubishi | 0 | 10-14-2002 09:56 |
