Old 05-28-2015, 16:36   #1 (permalink)
Member: 2140825
Thanks Meter: 5
G920v diag port not there
Need help to enable diag serial port on 920v enable dm, set to dm modem adb, even did all the settings in *#9090# tried all three options, yes can change imei but need serial port for cdma workshop. anyone have a solution please post thanks
Old 05-28-2015, 21:01   #2 (permalink)
Member: 2279699
Thanks Meter: 41
boss type
##dmmode#
##366633#
also enable the hidden menu
The Following 2 Users Say Thank You to thejmf For This Useful Post:
Old 05-29-2015, 20:20   #3 (permalink)
Member: 2038839
Thanks Meter: 10
after ##366633# it connects as unknown device
hi, after ##366633# it connects as unknown device
tried new drivers same thing diag port is not openning
changed usb changed pc
Old 06-05-2015, 03:56   #4 (permalink)
Member: 1601594
Thanks Meter: 13
Cool
for Verizon you need factory firmware
not next to the phone but the q used in the factory
* this has enabled serial ports
someone will have the file you need
Old 06-05-2015, 06:23   #5 (permalink)
OscarR87's Avatar
Member: 2213954
Thanks Meter: 39
Make sure to boot to RECOVERY and enable CP LOGGING, phone will restart and now you should be able to get diag mode.
Old 06-19-2015, 21:57   #6 (permalink)
Member: 1991594
Thanks Meter: 14
still cant
so I have the hidden menu enabled and I selected dmmode however it still shows as device as unknown. Any help much appreciated
Old 06-19-2015, 22:24   #7 (permalink)
Member: 1347382
Thanks Meter: 85
need to flash factory bin firmware to enable serial ports.
Old 06-19-2015, 22:44   #8 (permalink)
Member: 1991594
Thanks Meter: 14
where to get bin?
Please tell me where to get that from I will pay you for the info.
The Following User Says Thank You to xboxtimus For This Useful Post:
Old 06-19-2015, 22:56   #9 (permalink)
Member: 1347382
Thanks Meter: 85
are you trying to flash the phone to a cdma carrier?
Old 06-19-2015, 23:01   #10 (permalink)
Member: 1991594
Thanks Meter: 14
port issue
I'm trying to write a cert on it but I cant seem to connect it to any port
Old 06-19-2015, 23:02   #11 (permalink)
Member: 1347382
Thanks Meter: 85
I see..well just so you know verizon s6 use a different keyID cert..
Old 06-19-2015, 23:29   #12 (permalink)
Member: 1991594
Thanks Meter: 14
yes bro its 0053 I have all certs clean
Old 06-20-2015, 00:04   #13 (permalink)
Member: 1347382
Thanks Meter: 85
sent you a pm. mmm
10 chars
Old 07-01-2015, 04:22   #14 (permalink)
Member: 2256304
Can you help us, I dont know how to enable diagnostic mode g920v (galaxy s6 verizon)
Old 07-01-2015, 13:31   #15 (permalink)
Member: 2076039
Thanks Meter: 648
Look above. Its all been covered in this thread. If you still cant get it to work then theres an issue with the phone
The Following User Says Thank You to ecs87 For This Useful Post:
Page generated in 0.22619 seconds with 8 queries
