10-05-2018, 22:34 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: El Salvador
Member: 225008 Status: Offline Thanks Meter: 11 | unlock SM-N950U, B3 [Answered] Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will appear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Unlocking using Server: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-N950U Selected port: COM775 SAMSUNG Mobile USB Serial Port Software version: 33.8 Checking Login and Password... OK Ballance: 15 crd. You have 15 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-N950U Android version: 7.1.1 PDA version: FA71_N950USQU3ARA1 CSC version: Phone version: N950USQU3ARA1 Product code: SM-N950UZKACCT CSC country code: CSC sales code: Phone SN: R28K12ZMMLN IMEI: 358xxxxxxxxxxxxx HW version: REV1.0 RF cal date: 2018.01.19 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-07-01 Boot Warranty bit: 0 Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM62 detected Reading data from phone... error (3 2) Done with Samsung Tool PRO v.33.8 |
10-05-2018, 23:17 | #2 (permalink) | |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Quote:
