04-21-2015, 18:52 | #112 (permalink) |
Freak Poster Join Date: Feb 2005 Location: egypt
Member: 119435 Status: Offline Thanks Meter: 54 | G360f unlock error Reading phone info... Reading IMEI... OK IMEI: 3593600 Reading security... error Detected new type of security Bypassing... OK Unlocking... error Done with Samsung Tool v.20.0 |
04-21-2015, 18:55 | #113 (permalink) | |
Freak Poster Join Date: Apr 2006
Member: 254271 Status: Offline Thanks Meter: 17 | Quote:
Addition function added name: SAFE DIRECT UNLOCK WITHOUT WIPE EFS, WITHOUT KNOX RESET, WITHOUT ROOT + added important function WRITE CERT VIA USB CABLE without root for cert based phones. The Last Line of the post has the following models SM-N900P,SM-N900R4,SM-N900S,SM-N900T,SM-N900U,SM-N900V,SM-N900W8,SM-N910A, SM-N910F,SM-N910G,SM-N910P,SM-N910R4,SM-N910T,SM-N910W8,SM-T217A,SM-T217T. so i head on in to Z3X Samsung Tool v20.0 and find SM-N910A for imei repair i get the directions. BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on "Build number" in "Settings"-"About phone" to enable "Developer options", go to "Settings"-"Developer options" and enable "USB debugging". 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press "Read EFS" button to read backup or "Write EFS" to restore or press "Write CERT" to restore certificates. am i missing something i need to repair this phone but this box still cant do it... | |
04-21-2015, 19:08 | #117 (permalink) |
Insane Poster Join Date: Mar 2006
Member: 252293 Status: Offline Thanks Meter: 16 | Mr. Blang, When will be the official release of the Samsung Pro Final? Since some of our box is already on the 8th months and if it will be release long enough we will not be able to avail for our free activation. I am suggesting that we could start the activation process in the soonest possible time. I am hoping for your kind consideration about this matter. Thank you and Best Regards, |
04-21-2015, 19:11 | #118 (permalink) |
Freak Poster Join Date: Aug 2009 Location: NYC
Member: 1105429 Status: Offline Thanks Meter: 118 | I'm unable to run the 20.0 .. stuck at the Samsung tool splash screen.. Do I have activate Samsung Tool Pro first? or the beta? $60 is NO problem at all.. i just wanted to make sure the reason why it's not running if it's because it's not activated or my pc problem. |
04-21-2015, 19:12 | #120 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,561 | Quote:
