02-22-2016, 21:33 | #1 (permalink) |
Insane Poster Join Date: Jan 2016
Member: 2510231 Status: Offline Thanks Meter: 11 | z3x domestic unlock sm-n910p says ok, but the true is not...any advice? Already domestic unlock for sm-n920p,sm-n928p,sm-n925p with out any problem. ONLY SM-N910P UNLOCK ITS NOT WORKING |
02-22-2016, 21:46 | #2 (permalink) |
Registered User Join Date: Apr 2010
Member: 1290061 Status: Offline Thanks Meter: 61 | Maybe if you searched a little you could have the solution to your problem. You have to enable GCF. Enable airplane mode Go to Settings Activate device press ok and press menu button press PST TESTMODE MENU the follow steps. Dial *#0011#, menu, Key Input Capital "Q", menu, back, Key Input "0000" Wait a few seconds. Follow these steps: A. click ue setting and info B. click setting C. click protocol D. open gcf and click number 1 and make sure it is on. E. Restart the phone |
The Following User Says Thank You to george241312 For This Useful Post: |
02-22-2016, 21:55 | #4 (permalink) | ||
Member: 1290061 Status: Offline Thanks Meter: 61 | Well then RIP Root it and do this command from adb shell over USB DEBUG Quote:
02-22-2016, 21:57 | #5 (permalink) |
Member: 1290061 Status: Offline Thanks Meter: 61 | if still not working do ##72786# this will reset network settings and relock the phone and put it back to stock CDMA wise could be a messed up settings if that fails downgrade firmware or factory reset. |
The Following 3 Users Say Thank You to george241312 For This Useful Post: |
02-22-2016, 22:15 | #6 (permalink) |
Member: 2510231 Status: Offline Thanks Meter: 11 | Ok ,already factory reset, do all unlock work and the same but issue, I reset the network settings and went for gcf and its working, now its showing the menu. Really Appreciate your help. Thank you |
The Following User Says Thank You to miguelstorres For This Useful Post: |
03-21-2016, 17:50 | #8 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2016
Member: 2532914 Status: Offline Thanks Meter: 1,154 | It is pretty simple. If GCF menu is not available just root phone and then bring up command prompt and enter the following: adb shell su am broadcast -a android.provider.Telephony.SECRET_CODE -d android_secret_code://27663368378 That will force hidden menu to show then just select following: UE SETTINGS & INFO SETTING PROTOCOL GCF GSM/(E)GPRS/WCDMA GCF ON That simple. It works on N915P too. |
The Following User Says Thank You to markhaines1985 For This Useful Post: |
03-21-2016, 17:55 | #9 (permalink) |
Freak Poster Join Date: Nov 2014
Member: 2291117 Status: Offline Thanks Meter: 34 | if you dont know how to use command prompt you can always install the app samsung *phone info* from the market place and send the code from that app and it will take you to the service settings remember it has to be rooted |
03-22-2016, 01:37 | #11 (permalink) |
Freak Poster Join Date: Apr 2015 Location: Caribbean Island
Member: 2381538 Status: Offline Thanks Meter: 92 | Bro contact via skype i will help you no charge just buy me a beer when its done |
The Following User Says Thank You to jjmpda For This Useful Post: |
