04-25-2016, 22:45 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: USA
Member: 575293 Status: Offline Thanks Meter: 40 | Z3X LG 2-3G Tool 9.7 Nexus 5X 6.0.1 April Security Patch FRP Bypassed! Using Z3X and LG 2-3G Tool in testing I first soft bricked the device trying a similar in number device (H901), second try I used (H968) and it worked. Here are the results: LG 2-3G Tool v9.7 supported models: 1155 Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 2 secs. --> (v9.7) Mode: Emergency Model: H901 Elapsed: 2 secs. --> (v9.7) Mode: Emergency Model: H901 Elapsed: 2 secs. --> (v9.7) Phone mode is DOWNLOAD Start FRP remove... LAF: 01000002 Model name: LGH790 Software verion: LGH790AT-00-V10f-NXS-XXX-OCT-03-2015-32G-MDA89E-US Android verion: 6.0 IMEI: 35362XXXXXXXXXX 3 Patching... 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 FRP Reset Done. Elapsed: 53 secs. --> (v9.7) Not detect phone! Please manual select port or reboot PC! Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 2 secs. --> (v9.7) Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 2 secs. --> (v9.7) Mode: Emergency Model: H968 Elapsed: 2 secs. --> (v9.7) Mode: Emergency Model: H968 Elapsed: 2 secs. --> (v9.7) Phone mode is DOWNLOAD Start FRP remove... LAF: 01000002 Model name: LGH790 Software verion: LGH790AT-00-V10f-NXS-XXX-OCT-03-2015-32G-MDA89E-US Android verion: 6.0 IMEI: 35362XXXXXXXXXX Restore data detected! Restore DONE! Elapsed: 2 secs. --> (v9.7) |
The Following 4 Users Say Thank You to cellfonepimp For This Useful Post: |
04-26-2016, 23:36 | #6 (permalink) |
Freak Poster Join Date: Oct 2014
Member: 2277857 Status: Offline Thanks Meter: 68 | I tries using H968 and Z3X doesn't detect the phone. Are you saying you have to soft brick it first in order for it to work? After it soft bricked, you were still able to get into download mode? |
04-27-2016, 00:07 | #7 (permalink) | |
Member: 575293 Status: Offline Thanks Meter: 40 | Quote:
Do you have the drivers installed? You can bypass the activation using this video https://www.youtube.com/watch?v=HuPIhiFZoaI But that does not work on the new April security patch. If you can get access to settings and install drivers from Google, I also put it in fastboot mode and maybe that installed other drivers as well. Fastboot mode is hold VolUp/Dn and PWR, connect USB and see if it installs add'l drivers. Last edited by cellfonepimp; 04-27-2016 at 00:10. Reason: download explanation | |
The Following User Says Thank You to cellfonepimp For This Useful Post: |
04-27-2016, 00:19 | #8 (permalink) |
Member: 2277857 Status: Offline Thanks Meter: 68 | No, not soft bricked and yes, I have the latest security patch because all the online solutions don't work anymore. Don't think it's a driver issue and fastboot doesn't add any drivers. Not getting any ports to open. |
04-27-2016, 00:50 | #10 (permalink) | |
As I mentioned I tried so many things in a span of 2 days and before I tried the tool again I was ready to try a new firmware also. But then it bypassed and it fixed the soft brick (error I had was gco/recovery - abh) | |
04-27-2016, 03:24 | #11 (permalink) |
Member: 2277857 Status: Offline Thanks Meter: 68 | Thanks for the info, I can only think it's a driver issue, shows up when started normally, but nothing in download mode. I reinstalled drivers, but no luck. If anyone has a suggestion, it would be welcomed. |
04-27-2016, 21:52 | #15 (permalink) | |
Member: 2277857 Status: Offline Thanks Meter: 68 | Quote:
Do you mean in LG Tool after selecting H968? If so, yes, I tried but no dice. If I could open the port, I would be home free. I've seen thin on some other LG phones, but I was able to get around it because it they weren't locked. I have worked on tons of LG and Nexus phones, so not sure if there is a driver issue with this phone or if somehow you opened up something when you soft bricked. All i get is the timeout message but that makes sense because no ports are open. | |
