Old 06-20-2013, 18:08   #1 (permalink)
Member: 150457
Thanks Meter: 16
How to activate Iphone4 after upgrade??Help
Hi mates,
i need help.A friend of mine received a deactivated iphone , after upgrade to 6.1.3 needs to be activated but i cant do it.
Whats the correct procedure to solve this issue??
regards.
Kife
Old 06-20-2013, 18:20   #2 (permalink)
Member: 1338781
Thanks Meter: 46
You can try with original sim card or install just cydia with redsnow.it will activate your phone
Old 06-20-2013, 18:22   #3 (permalink)
unlock.mk's Avatar
Member: 1671934
Thanks Meter: 247
just use original SIM card from operator that iPhone was bought from.
Old 06-26-2013, 12:56   #4 (permalink)
Member: 150457
Thanks Meter: 16
Always give me errorrs
Any other idea?
Regards
Kife
Old 06-26-2013, 13:00   #5 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
Thanks Meter: 4,949
@ kife
Be more specific with errors logs or screenshot, may be its locked or what ?
Old 06-26-2013, 14:13   #6 (permalink)
Member: 1450009
Sonork: coloriteman
Thanks Meter: 2
If you're using iPhone 4 or 3GS, you can use Redsn0w to activate your device on iOS 6.1.3. Follow this method..Jailbreak and activate iPhone 4, 3GS on ios 6.1.3 with Redsnow 0.9.15b3
Old 06-26-2013, 21:28   #7 (permalink)
BB-gsm's Avatar
Member: 75765
Thanks Meter: 722
If it refuses to activate, it might be blacklisted .
Actually, in 99% of cases, this is the reason .
Regards
Old 07-03-2013, 13:08   #8 (permalink)
Member: 150457
Thanks Meter: 16
Hi,
Really thanks all for replies
I found out its locked.Is it possible to unlock it without buying codes??
0132************
Part Description: IPHONE 4 8GB BLACK
Product Version: 6.1.3
Coverage Status: Apple Limited Warranty
Coverage End Date: 21/05/14
First Unbrick Date: 22/05/13
Last Unbrick Date: 22/05/13
CTN: 4*********
Next Tether Activation Policy Description: Norway Telenor.
Lock Status: Locked
Regards
KIFE
Old 07-03-2013, 14:28   #9 (permalink)
Member: 319447
Thanks Meter: 4,949
@ kife
For now, only *** can help you for free.........
Old 07-03-2013, 17:01   #10 (permalink)
Member: 150457
Thanks Meter: 16
THANX FOR YOUR REPLY MR. SUBRATA.
I only wanted to know if there was other choice,different of codes.Realize its not.
Thanx
Kife
Old 07-09-2013, 07:06   #11 (permalink)
Member: 1974792
Thanks Meter: 3
Just Follow Some Steps Are :
>> Restart The Phone Than Again Try For Activation
>> If Not Again Done Than Turn OFF The Phone And Remove The Battery And Insert Battery And Turn ON The Phone
>> Than Try Again Than You Have Successfully Activated The Phone
>> If Not Than Restore The Phone Than Your Mobile Works Fine.
Page generated in 0.19153 seconds with 8 queries
