06-20-2013, 18:08 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 43
Member: 150457 Status: Offline Thanks Meter: 16 | How to activate Iphone4 after upgrade??Help i need help.A friend of mine received a deactivated iphone , after upgrade to 6.1.3 needs to be activated but i cant do it. Whats the correct procedure to solve this issue?? regards. Kife |
06-26-2013, 14:13 | #6 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1450009 Status: Offline Sonork: coloriteman Thanks Meter: 2 | If you're using iPhone 4 or 3GS, you can use Redsn0w to activate your device on iOS 6.1.3. Follow this method..Jailbreak and activate iPhone 4, 3GS on ios 6.1.3 with Redsnow 0.9.15b3 |
07-03-2013, 13:08 | #8 (permalink) | |
Member: 150457 Status: Offline Thanks Meter: 16 | Hi, Really thanks all for replies I found out its locked.Is it possible to unlock it without buying codes?? Quote:
KIFE | |
07-09-2013, 07:06 | #11 (permalink) |
Junior Member Join Date: Jul 2013 Age: 44
Member: 1974792 Status: Offline Thanks Meter: 3 | Just Follow Some Steps Are : >> Restart The Phone Than Again Try For Activation >> If Not Again Done Than Turn OFF The Phone And Remove The Battery And Insert Battery And Turn ON The Phone >> Than Try Again Than You Have Successfully Activated The Phone >> If Not Than Restore The Phone Than Your Mobile Works Fine. |
