10-30-2007, 22:37 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | activate iphone without its original simcard ? how ? i got iphone for unlocking .... thought its first time runing and it ask for activation .... thought it wont activete cuz i dont have original simcard ... is ther any way to bypass this ? |
The Following User Says Thank You to TRABEL For This Useful Post: |
10-31-2007, 00:10 | #2 (permalink) |
Member: 21937 Status: Offline Thanks Meter: 279 | k after read alot .... i have found small app , insert any sim , get itunes iTunes 7.3.0.54 installed and run this app. this will not unlock your iphone sim free , but it will pass the anoying activation request , and keep you from doing many emergency calls in order to find wifi conection and access online. http://www.***********/softsell/visit...Setup3.0.5.exe |
10-31-2007, 11:43 | #3 (permalink) | |
Freak Poster Join Date: Oct 2003 Location: nigeria
Member: 41664 Status: Offline Thanks Meter: 37 | Explain More Quote:
PLEASE I RUN THE APPLICATION AND IT ASK ME TO CONNECT MY IPHONE TO MY COMPUTER AGAIN ...AND IT WILL BE UNLOCKED .............( SHLD MY IPHONE BE CONNECTED BEFORE RUNNING THE SOFTWARE , OF AFTER RUNING THE SOFTWARE PLEASE). THANK YOU JUSTX24 | |
10-31-2007, 17:38 | #6 (permalink) | |
Member: 21937 Status: Offline Thanks Meter: 279 | Quote:
tested this app yesterday on 1.1 iphone , unactivated. this soft only active your iphone if you dont have original at&t sim card install this version of itunes , run this app and it say connect your iphone. connect it with any sim card , itunes should turn on without any error. after this turn off iphone and turn it back on (fully off) | |
11-01-2007, 17:52 | #7 (permalink) |
Crazy Poster Join Date: Jun 2004 Age: 42
Member: 68926 Status: Offline Thanks Meter: 2 | Bypass activation and prepare phone for software installation Make sure there's a sim-card inserted, and power on your phone (an AT&T card is already inserted when you buy the phone). On the activation screen, slide to emergency and dial: *#301# to make the phone call itself. (If the incoming call dialog quickly disappears but it keeps ringing, just dial 0 (remove *#301# first), and it will call itself) Answer the call, and tap on Hold Phone will call it self again, tap Decline. You will now be returned to the normal dialer. Tap on contacts, and tap the + icon to add a new. The only info you are going to add to this contact are two URL's. To add a URL, tap Add new URL. The first URL is prefs followed by a colon: prefs: and the second is jailbreakme.com. Tap Save. Your contact now has two "web pages" - tap on the first one (prefs. This will take you to the settings dialog. The reason you want this, is because you need to connect to a Wi-Fi network, so tap on Wi-Fi, and get connected to a network, and make sure the icon on top of the screen is indicating that you are connected. While you are in the settings dialog, you should also set: General → Auto-Lock → Never. Now, press the home button, and again, slide to emergency dial 0, Answer the call, Hold and Decline the new call so that you get to the contacts. Tap on your contact (No Name), and this time tap on the other home page, jailbreakme.com Safari will launch and show you a webpage. Read through the text, before you Install AppSnapp Phone will return to activation screen, but don't panic, just wait. Phone will eventually call it self again, but this time, just restart the phone, by holding down the power button for 5 seconds. Start the phone again, and you should be taken directly to the home screen! Activation is now bypassed, and phone prepared for software installation! Unlock the SIM-lock Open installer, and install the update if prompted. Go to sources and tap Edit and Add Add this URL: i.unlock.no Tap Done and then Refresh Go to Install (at bottom) and scroll down to the category "System" Install BSD Subsystem (this may take some time) When done, go to Unlocking Tools category and install AnySIM (ignore the others, they are already installed if you followed this tutorial) When installed you can press the home button, and you will find a new AnySIM icon on your home screen. Launch it and follow the instructions. The unlocking process will take about 5-10 minutes, in the end it should say it was successful! To clean up your phone, launch Installer, and uninstall AnySIM and BSD Subsystem. Lastly, go to Settings → General → Auto-Lock and set it to a prefered value. If YouTube does not work ("You must first connect to iTunes..."), install YouTube activation which is found in the Unlocking tools-category(you done ur i-phone unlocking without pc u only need wi-fi network no need to downgrade) |
01-07-2009, 01:46 | #8 (permalink) |
Junior Member Join Date: Jan 2009
Member: 941119 Status: Offline Thanks Meter: 1 | ok so i bought an i phone that was unlocked but when i connected it to my itunes (laptop) i didnt know i wasnt meant to update it and i did!i dont have the original sim!!now my phone doesnt work!on the screen is just the usb icon and itune icon and slide for emergency call!!is my phone broken forever?is there something i can do?please please please help if you can, otherwise i just wasted 400euro!!oh im so worried im freakin out! |
The Following User Says Thank You to JennyMcM For This Useful Post: |
07-02-2009, 00:59 | #10 (permalink) |
Junior Member Join Date: Feb 2005 Age: 42
Member: 121592 Status: Offline Thanks Meter: 3 | Is this an iPhone 2G, 3G or 3GS? Won't just flashing it with redsn0w activate and/or unlock it...?? Update to 3.0, pwn with redsn0w. Possibly download ultrasn0w through Cydia if applicable... Simple as that... unless i"m missing something here... |
The Following User Says Thank You to Evil Ernie For This Useful Post: |
08-16-2009, 06:36 | #11 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1097419 Status: Offline Thanks Meter: 1 | hi i've got an 16GB iphone that was running well on the firmwork 1.1.4, but when i updated it to the lates firmwork it asked me to insert the original sim card to activate the iphone. i dont have the original sim card and i've tried the (Unlock-iphone) program and it showes me ( check itune 3.7.0.54 failed ). can anyone help me plz. thnx. |
The Following User Says Thank You to wrxsti For This Useful Post: |
Hot!!active iphone 3gs without simcard!!! | hueddc | iPhone 2 / iPhone 3G / iPhone 3GS | 24 | 05-05-2010 07:57 |
iPhone 3gs that is from o2 carrier U.K, can it be unlock without original simcard? | mymiela0419 | iPhone 2 / iPhone 3G / iPhone 3GS | 3 | 01-06-2010 06:18 |
How to activate iphone without original sim card | arwanis | iPhone 2 / iPhone 3G / iPhone 3GS | 3 | 11-04-2009 00:47 |
activate iphone without locked sim | ZIYAAD STRYKER | iPhone 2 / iPhone 3G / iPhone 3GS | 3 | 07-06-2009 18:49 |
spv c500 unlock without original simcard | patric | HTC & PDA WM( With Touchscreen) | 5 | 11-23-2005 20:07 |
