Old 01-08-2010, 20:39   #1 (permalink)
Member: 36698
Thanks Meter: 4
Exclamation iPhone 3G only turns on with charger connected!!
Hello guys,
I have a iPhone 3G that only turns on (but don't start at all) with the charger connected. I've changed the battery for a new one and its the same thing. And better than that, I've changed his mother-board, for another one. Well, this mother-board in another chassis(and everything new) doesn't work either without charger connected, and a good board on the chassis of damaged iPhone worked fine! So, I concluded that the problem is on Board!
With charger, iPhone turns on, appears the Apple logo but nothing else, he doesn't really starts. And I'm sure it isn't a SW or FW problem. It is for sure a HW problem.
Anyone have an idea of what is the problem?
Regards,
SoSimple
Old 01-09-2010, 17:22   #2 (permalink)
Member: 36698
Thanks Meter: 4
Any solution?
Regards,
SoSimple
Old 01-10-2010, 00:22   #3 (permalink)
Member: 1187598
Sonork: shofiqur007
Red face Above same problem, can any one help us!
Above same problem, also I'm facing can any one help us!
Old 01-10-2010, 00:43   #4 (permalink)
Member: 917893
Sonork: 100.1584763
Thanks Meter: 3,156
Originally Posted by SoSimple View Post
Hello guys,
Regards,
SoSimple
do a reflow of ic' s
Old 01-10-2010, 03:00   #5 (permalink)
Member: 36698
Thanks Meter: 4
I've done already, didn't solved.
Regards,
SoSimple
Old 01-10-2010, 03:19   #6 (permalink)
alex_030385's Avatar
Member: 875541
Sonork: 100.1604468
Thanks Meter: 327
sir try to change battery.....
Old 01-10-2010, 12:08   #7 (permalink)
Member: 335748
Plug it into the pc and if necessary reboot the pc.
Old 01-10-2010, 23:11   #8 (permalink)
Member: 496243
Thanks Meter: 42
How do you do a reflow my friend? I got a 2G is doing the same thing, it will not turn on by pressing the power button, it only turn on when you connect the charger to it, then you can disconnect the charger and every thing works fine as long as you don't turn it off, but you can press the power button and slide to turn it off, any ideas?
Regards
Old 01-19-2010, 02:07   #9 (permalink)
Member: 917893
Sonork: 100.1584763
Thanks Meter: 3,156
Regards
reflow mean heat intergrated circuits with hot air machine
Old 01-19-2010, 02:17   #10 (permalink)
Member: 81445
Thanks Meter: 14
Switch ic.........MR GSMman187
Old 01-19-2010, 02:20   #11 (permalink)
Member: 917893
Sonork: 100.1584763
Thanks Meter: 3,156
hahah yea that too if reflow dont work,
how are ya man... ?
Old 01-22-2010, 08:47   #12 (permalink)
Member: 36698
Thanks Meter: 4
how are ya man... ?
What IC by the way? Don't you have a scheme?
Regards
Old 01-22-2010, 08:47   #13 (permalink)
Member: 36698
Thanks Meter: 4
Does anyone have a service manual for iPhone 3G? I need to check layers...
Regards
Old 01-22-2010, 15:25   #14 (permalink)
Member: 893844
remove your screen protector and see if the problem still persists.
Cheers!
Old 01-22-2010, 15:49   #15 (permalink)
Member: 36698
Thanks Meter: 4
Cheers!
It doesn't have screen protector or anything like that... Thanks anyway dude!
Regards
Samsunf S5230 only turns on with charger connected Help!! cellularmax Samsung Hardware Repair 4 12-31-2010 00:15
iPhone 3G...Not Turning On fortzum iPhone 2 / iPhone 3G / iPhone 3GS 14 03-07-2010 15:30
iPhone 3G don't turn on Mikki83 iPhone 2 / iPhone 3G / iPhone 3GS 15 07-13-2009 17:58
A920 turn on with charger only moustafatch Motorola Hardware Repair 0 09-14-2005 15:53
after "unlocking" T20s only turns on with cable connected achie Old Ericsson Phones & Sony Phones 1 07-11-2001 21:28
Page generated in 0.33834 seconds with 10 queries
