01-03-2013, 16:06 | #1 (permalink) |
Crazy Poster Join Date: Feb 2006
Member: 230213 Status: Offline Thanks Meter: 5 | iphone 3gs Baseband 05.16.07 problem for unlock all I have iphone 3gs ios 6.0.1 Baseband 05.16.07 it unlocked done by server But I cannot upgrade or Downgrade bb from 05.16.07 still same please help me how to solve the problem Thanks in Advanced B.R. Kayes |
01-03-2013, 20:50 | #2 (permalink) |
No Life Poster Join Date: Feb 2010 Location: India
Member: 1229111 Status: Offline Sonork: 100.1615835 Thanks Meter: 1,120 | For BB downgrade, first u have to use redsn0w to update to ipad baseband 6.15 and then downgrade it to 5.13. But since u have done server unlock, it is not needed. Just y do u want to up/dn BB?? |
01-04-2013, 08:48 | #3 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: P A K I S T A N
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | Quote:
For the safety. If you found it safe to flash IPAD baseband then you are safe and just do it. --------------------------------------------------------- Best Regards GSM-DOCTOR Follow the rules i have to learn english | |
01-04-2013, 09:09 | #5 (permalink) | |
You don't need to downgrade or upgrade you phone's bb if you have unlocked by server. --------------------------------------------------------- Best Regards GSM-DOCTOR Follow the rules i have to learn english | |
01-04-2013, 10:20 | #6 (permalink) | |
Member: 230213 Status: Offline Thanks Meter: 5 | s/n Quote:
SN is:87123Q07EDG | |
01-04-2013, 10:22 | #7 (permalink) |
Freak Poster Join Date: Nov 2009 Location: phiplipens
Member: 1160964 Status: Offline Sonork: 1619850 Thanks Meter: 49 | MASTER TESTED SULOTIN YOUR PROBLIM BB UP DATE STEP-1 YOUR WINDS-7 STEP-2 USE redsn0w 0.9.6b6 Oke.... i hope your problim is done... No ned Downgred or up gred master.... |
01-04-2013, 10:24 | #9 (permalink) |
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | Dear if you factory unlocked your phone then no need S/N check or baseband update. Just restore to the latest IOS and activate with any GSM SIM card. --------------------------------------------------------- Best Regards GSM-DOCTOR Follow the rules i have to learn english |
01-04-2013, 10:32 | #10 (permalink) | |
Member: 230213 Status: Offline Thanks Meter: 5 | remain unchanged BB Quote:
Dear after update to 6.0.1 the mobile BB still 05.16.07 (not changed) that is why it's not unlocked though unlock done by server if BB goes to 6.15 then it will be unlocked | |
01-04-2013, 10:46 | #11 (permalink) |
Insane Poster Join Date: Aug 2012
Member: 1803955 Status: Offline Sonork: 1001617675 Thanks Meter: 42 | Fist check with imei checker with serial number checker software if ur serial number show gree then u can downgread if show red not use downgread fave unlocking if show red then use factr unlocking |
The Following User Says Thank You to Ash0887 For This Useful Post: |
01-04-2013, 11:10 | #12 (permalink) | |
If you have unlocked through server its called factory unlock. So you don't need any baseband changes because you have already official baseband and you can activate it with iTunes with any sim card. Baseband 6.15 is only for software unlock ( ultrasn0w unlock) So according to info you posted in the thread. You don't need upgrade or downgrade.you just need to activate your phone through iTune along with a GSM SIM inserted . Now clear??? --------------------------------------------------------- Best Regards GSM-DOCTOR Follow the rules i have to learn english | |
The Following User Says Thank You to GSM-DOCTOR For This Useful Post: |
01-04-2013, 11:11 | #13 (permalink) |
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | And if want a software unlock then i can help you better. But first of all you have to explain that what is that ??? Which is calling server unlock --------------------------------------------------------- Best Regards GSM-DOCTOR Follow the rules i have to learn english |
01-12-2013, 04:43 | #14 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 45
Member: 132735 Status: Offline Thanks Meter: 88 | your serial number looks not possible to play it. or else do it with your own risk. but i suggest you to dont try it. the two types of unlock in 3gs is: server unlock = no need any soft to use, its plug and play in any BB version. ultrasnow unlock =must move BB to make it supported in order unlock. hope it will clear you bro. |
