07-28-2011, 23:57 | #1 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 240988 Status: Offline Thanks Meter: 45 | IPHONE 4 Restore 4.3.5 and 4.3.4 always enter in dfu mode IPHONE 4 Restore 4.3.5 4.3.4 4.2.1 4.1 3.1.3. 4.2.1 4.1 always enter in dfu mode after restore PLEASE ANY proceedings to return to normal in ANY version HOW To Remove dfu Mode |
The Following 4 Users Say Thank You to agimsopa For This Useful Post: |
07-29-2011, 00:32 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2010 Location: Area 51 Age: 32
Member: 1236325 Status: Offline Sonork: 100.1616831 Thanks Meter: 272 | do u have any shsh saved bro ? if yes tell me which version i will help you |
The Following User Says Thank You to .:[Diamond]:. For This Useful Post: |
07-29-2011, 01:51 | #3 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | first if u dont have ur SHSH blobs saved u cant downgrade u can only update... |
The Following User Says Thank You to jusmejose For This Useful Post: |
07-29-2011, 03:30 | #4 (permalink) |
Crazy Poster Join Date: Mar 2009 Location: y6odf9idci9
Member: 999872 Status: Offline Sonork: fyofyoctoi Thanks Meter: 2 | man restor ur i phone from pc tiny umbrila is not opened befor in this pc ihave 7 iphone's do this problem and all fixed with this trik tel me what hapen after u flash iphone in another pc |
07-29-2011, 09:37 | #5 (permalink) |
No Life Poster Join Date: Oct 2002 Location: tunisia
Member: 16625 Status: Offline Sonork: 1578753 Thanks Meter: 161 | i have same problem with i phone 4 i tryed with saved shsh 4.3.3 with ifaith but at the end of restore give me error 37. i was on 4.3.4 with saved shsh on cydia but when i restore original 4.3.4 i get error 1013 and stuck in recovery mode i tryed every thing but cant leave recovery.!! any trick please? |
07-29-2011, 14:35 | #8 (permalink) | |
Freak Poster Join Date: Oct 2007
Member: 601134 Status: Offline Thanks Meter: 39 | Quote:
me too same with your problem | |
07-29-2011, 14:40 | #10 (permalink) | |
Freak Poster Join Date: Jul 2006 Location: Ahmedabad
Member: 320205 Status: Offline Thanks Meter: 181 | 100000% work Quote:
-------------------------------------------------------------------------------- use ireb for dfu mode then just run tinyumberla and start tss then restore custom fw(4.3.3) tested maybe work 4.1 too..will test and post today!!! pls wait!! send reply thanks | |
The Following User Says Thank You to sampat_shah For This Useful Post: |
07-29-2011, 15:03 | #11 (permalink) | |
Freak Poster Join Date: Jan 2010
Member: 1216441 Status: Offline Thanks Meter: 25 | Quote:
07-30-2011, 01:50 | #12 (permalink) |
Member: 16625 Status: Offline Sonork: 1578753 Thanks Meter: 161 | i made 4.3.3 custom with snowbreeze, put in dfu with redsnow run tss server in tinyumbrella all restoration went perfectly but at the end i am stuck in dfu loop y tryed all to fix it but invain only tethred boot work i tyed with 4.1 same result dfu loop!!! do i have to run tss server or only edit hosts file? or what should i do exactly? please help |
07-30-2011, 01:53 | #13 (permalink) |
Insane Poster Join Date: Oct 2009
Member: 1132097 Status: Offline Thanks Meter: 4 | same here "i made 4.3.3 custom with snowbreeze, put in dfu with redsnow run tss server in tinyumbrella all restoration went perfectly but at the end i am stuck in dfu loop y tryed all to fix it but invain only tethred boot work " [2] stock 4.3.3 firmware too, DFU loop... solution? |
07-30-2011, 03:13 | #14 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: E G Y P T Age: 37
Member: 527884 Status: Offline Sonork: 100.1583794 Thanks Meter: 850 | Quote:
Regards And One Advice For All ( There Is No Solution To Downgrade Without (SHSH) And Donot Read And Thread Strat By Downgrade Without SHSH Caz It Fake caz Simply Iphone Must Be Verfyiyng With Apple Server Or Saruik To Get Fully Workd Restore Without Stuck D F U Last edited by shedeed; 07-30-2011 at 03:20. | |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
