07-23-2012, 19:09 | #1 (permalink) |
Crazy Poster Join Date: Jan 2005 Age: 39
Member: 108544 Status: Offline Thanks Meter: 4 | iphone 4 stuck on dfu mode i got a iphone 4 stuck on dfu mode, i am trying to jailbreak it with redsn0w but it says usb communication problem. i have tried with other iphone 4 it also says usb communication problem. if i try to restore it with itunes it just says preparing iphone to restore and does not do anything. need your profesional help. |
07-23-2012, 19:25 | #2 (permalink) |
Junior Member Join Date: Jul 2012
Member: 1787088 Status: Offline Thanks Meter: 7 | hold home and power for 15 seconds, it should restart. Also think you need to sort the USB problem out befor you try again to JB |
The Following User Says Thank You to Heavy Smoker For This Useful Post: |
07-23-2012, 20:21 | #3 (permalink) | |
Freak Poster Join Date: May 2007
Member: 501219 Status: Offline Thanks Meter: 27 | Quote:
The phone I have has never been open before never dropped Can anyone try help us please Custmar thinks I'm taking the piss | |
07-24-2012, 13:08 | #5 (permalink) | |
I reinstalled windows on my laptop Installed itunes tryed a restore I got an error 1601 witch means uninstall all of itunes and anything else that goes with it so i did and then reinstalled itunes after a restart restarted again and tryed the restore error 1601 again any help please | |
07-24-2012, 15:21 | #6 (permalink) | |
Member: 1787088 Status: Offline Thanks Meter: 7 | Quote:
If so: Here is a simple trick you can use to Bypass that dreaded iTunes error 1600 on your iPod touch, iPhone, or iPad. This will work with any 16xx error, such as error 1601, 1602, 1603 and 1604. For those of you who want to know why your encountering this error, its because the device wasn’t properly put in DFU mode when attempting to have iTunes restore the custom ipsw with the device. For Mac users we are going to use redsn0w to fix this problem and enter our device into a pwned DFU mode that will work when we restore our custom ipsw with iTunes. For windows users use iH8Sn0w’s iReb RC4. It is very simple to use and will work like a charm for all 16xx errors. However you can use Redsn0w as well. But iReb doesn’t currently work for Mac. But luckily we can fix this iTunes error with Redsn0w anyway and it just takes a minute. First open up Redsn0w, and select your stock ipsw. NOT the custom ipsw made with Pwnage Tool, Redsn0w won’t recognize it. Once you’ve done that press Next and it will process the ipsw. Again press next until you get to the screen below. Instead of clicking install Cydia, press Just boot into tethered DFU mode right now. (****NOTE**** If your Jailbreaking your device on 4.3.2, 4.2.8 or below, you can just check install Cydia now and jailbreak it at this point right now without having to use your custom ipsw fyi. But that isn’t always the case.) Then turn off your device and press next… Then follow the prompt to put your device into DFU mode. It will say finished and then your good to open up iTunes and restore your iDevice with your custom ipsw. And voila that’s all there is too it. | |
07-25-2012, 00:44 | #8 (permalink) |
Member: 1787088 Status: Offline Thanks Meter: 7 | Windows: Step 1: First open up Redsn0w Step 2: Select your stock ipsw (NOT the custom ipsw made with Pwnage Tool, Redsn0w won’t recognize it.) Step 3: Press Next and it will process the ipsw Step 4: Again press next until you get to the screen where it says install cydia but DON'T install cydia. Press Just boot into tethered DFU mode right now Step 5: Then turn off your device and press next Step 6: Then follow the prompt to put your device into DFU mode again Step 7: It will say finished and then your good to open up iTunes and restore your iDevice with your custom ipsw. Please post back if you get it sorted and good luck |
07-30-2012, 15:05 | #11 (permalink) |
Member: 501219 Status: Offline Thanks Meter: 27 | I fixed it (",) I used redsn0w Run redsn0w Go to extras/even more/ DUF IPSW/ and created a DUF IPSW close Redsn0w open itunes and restored with the DUF IPSW working now 100% thank for all your help |
The Following User Says Thank You to gitgray For This Useful Post: |
07-31-2012, 08:03 | #12 (permalink) |
Freak Poster Join Date: Jan 2012
Member: 1717046 Status: Offline Sonork: 100.1619225 Thanks Meter: 46 | 1. are you use original usb cable (in the box) 2. before you need to Jailbreak with Redsn0w latest version you have to power off your iphone before you plug - in than click next to Jailbreak hope to help you |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
