08-10-2013, 09:35 | #5 (permalink) |
Freak Poster Join Date: Dec 2011 Location: damak,jhapa,nepal
Member: 1705433 Status: Offline Sonork: kali Thanks Meter: 45 | if your device ios is 6.0 and later then you need to connect device with iTunes after remove battery ( some times its works with set time & date) ,if you already sync once device then also unable to call or call ended, just check setting>phone>show my caller id should be on. but be sure that your sim is detect by device,i mean searching without sim. |
08-12-2013, 13:23 | #6 (permalink) |
No Life Poster Join Date: Oct 2002
Member: 16943 Status: Offline Thanks Meter: 35 | hi how i i have told, i changed the screen, well, in a first moment, the phone not recognice the sim. then i plug the phone to the computer and with itunes i solve that problem. after that the phone recognice the sim, i input the sim code and i have signal with 3g logo. when i try to make a call, i have calling error or ended call. following your answers y look the time and date and they were in automatic, i change to manual and i have the time and date good. i try calling and i have the same error, calling error or ended call. then i go to settings/phone and i can see in my number i have unknown, the i write my number but still i have calling error o call ended. what can i do now? thanks |
08-12-2013, 13:38 | #7 (permalink) |
Member: 16943 Status: Offline Thanks Meter: 35 | hi another thing about this iphone: i go to settings/phone/show caller id and it is off, i change to on and try calling but the same problem, calling error or call ended. i back to caller id and is in off again, i don't know if this is normal everytime i enter in caller id. thanks |
08-14-2013, 19:50 | #8 (permalink) |
Insane Poster Join Date: Oct 2006 Location: kerala
Member: 363251 Status: Offline Thanks Meter: 9 | i saw i ur post tht u already checked the time to manual, but check whether year is also correct... me too had encountrd such problmes but date was wrong, when v remove the battery the year goes to 1970, dont know this will help or not but just telling my experiance, thnx |
08-14-2013, 22:24 | #9 (permalink) | |
Member: 16943 Status: Offline Thanks Meter: 35 | Quote:
time and date are correct thanks | |
09-14-2013, 12:36 | #11 (permalink) |
Member: 16943 Status: Offline Thanks Meter: 35 | hi sorry but i discovered what was the problem. the phone is from a friend but he forgot to tell me it was found by another friend. thanks |
The Following User Says Thank You to jak2812 For This Useful Post: |
09-14-2013, 12:52 | #12 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: India, Haldwani Age: 38
Member: 650289 Status: Offline Thanks Meter: 56 | Quote:
2nd - on off couple of times if not work - 3rd - full backup with itunes then restore (full erase) this is conman problem after disconcerting battery from terminal !!!!! | |
The Following User Says Thank You to hariichha For This Useful Post: |
09-14-2013, 13:25 | #13 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Syria ♪♫ Tartus Age: 47
Member: 299401 Status: Offline Sonork: facebook:Ahmad Majzoub Thanks Meter: 233 | bro . go to - settings > phone > show my caller id > & activite br, |
The Following User Says Thank You to disel center For This Useful Post: |
09-15-2013, 03:42 | #15 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 49
Member: 63120 Status: Offline Thanks Meter: 58 | xall problem 100!%solution only way is connect via usb to itunes to sync date and time, and if need restart phone after that if call is frozen before, tested on more than 500pcd after lcd replace ,always works...... that is all Last edited by skkeptik2; 09-15-2013 at 03:48. |
