06-25-2013, 19:52 | #1 (permalink) |
Freak Poster Join Date: Jun 2012 Location: Bd+Bh Age: 39
Member: 1775502 Status: Offline Sonork: 100.1618378 Thanks Meter: 221 | iphone 4s no service after LCD Replacement same time ok after no serviplease help me any solution |
06-25-2013, 20:07 | #3 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: P A K I S T A N
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | erase iPhone or IOS restore will fix beyond doubt anyhow if you have Cydia then you have another option od SAM Prefs add th source to the cydia Quote:
after that open SAM >> Utilities >> Deactivate iPhone and reactivate with iTune Done Enjoy........ Regards GSM-DOCTOR | |
06-25-2013, 20:44 | #4 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Kathmandu,Nepal Age: 46
Member: 983663 Status: Offline Sonork: 100.1623270 Thanks Meter: 551 | according you said problem created after replacement lcd, that seems hardware fault because you opened handset , so check well network clip near battery connector and some components near sub ant/s , also dont forget to put one clamp with battery connector which touch with back cover. |
06-26-2013, 00:16 | #7 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Town City Age: 54
Member: 37735 Status: Offline Sonork: 100.103255 Thanks Meter: 205 | you disconnected the battery from the board' now set correct date and time: go to airplane mode and set it on ! wait 5 seconds: set airplane mode off! wait and you will see searching- if no sim inserted; now you can see NO SIM !You can also try to synch phone with itunes and your date and time will be set automatically: common for 4s and i5! |
06-26-2013, 02:42 | #10 (permalink) |
Freak Poster Join Date: Mar 2003 Location: Naija
Member: 23834 Status: Offline Thanks Meter: 27 | [QUOTE=gsm_anwar;9526318]i phone 4s before network ok but lcd change network no service. same time ok after no serviplease help me any Adjust date and time to current state and restart your device. |
