12-29-2012, 18:03 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2007 Location: In the web Age: 37
Member: 622382 Status: Offline Thanks Meter: 201 | iphone 4s problem |
12-29-2012, 19:22 | #2 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: P A K I S T A N
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | Quote:
Connect your iDevice to your PC or Mac via USB cable and launch iTunes. Hold down the Home+Power button for 10 seconds. After 10 seconds, release the Power button but keep holding the Home button until iTunes detect your iPhone in recovery mode. Once your iDevice is in DFU mode, you should see nothing on its screen. It should be completely blank. Even if your iDevice is in DFU mode, iTunes will detect it as a recovery mode device and will display a message as shown in the above screenshot. As soon as you see the above message, restore custom IPSW and hopefully this time you will not get iTunes Error 21. --------------------------------------------------------- Best Regards GSM-DOCTOR Follow the rules i have to learn english | |
12-29-2012, 20:06 | #4 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 727810 Status: Offline Sonork: 100.1627301 Thanks Meter: 167 | i m also FACING THAt PROBLEM BT DIDNT cusTOMER TOOK HIS hANDSET BT i SAW A & SOLUTION SOMEWHERE TRY ITUNES 10.4 vErsIon & use i reb to put ur iphone in dfu mode & from snowbreeze make a custome firmware also edit host file , try this then post |
12-29-2012, 23:59 | #5 (permalink) | |
Moderator Join Date: Jan 2011 Location: Throne of GsmHosting
Member: 1483853 Status: Offline Sonork: 100.1611111 Thanks Meter: 1,628 | Quote:
at step 1,press and hold power+home for 10sec's step 2, release power button but keep holding home button till software detect your phone.... Custom restoration of iOS 4.X is currently off,So put phone pwn DFU and restore to official 4.1 thanks | |
12-30-2012, 05:05 | #6 (permalink) | |
The Following User Says Thank You to GSM-DOCTOR For This Useful Post: |
12-30-2012, 05:28 | #7 (permalink) | |
No Life Poster Join Date: May 2007 Location: Kolkata<<<India
Member: 505794 Status: Offline Sonork: 100.1627614 QQ:1958018248 Thanks Meter: 2,266 | Quote:
I think ur missing something Best Regards, Gsm Kolkata :-Think Different-: | |
The Following User Says Thank You to ..::Nokian CareŽ::.. For This Useful Post: |
12-30-2012, 07:01 | #11 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1860440 Status: Offline Thanks Meter: 0 | Lately iPhone problems have been more prevalent, especially regarding the headphones and headphone jack. These problems are being reported more and more, not only from iPhone users but across the Apple board.std tests |
12-30-2012, 08:04 | #12 (permalink) |
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | you are doing it wrong Plug USB to phone and PC Press and hold the both keys Power and home until the screen goes black. On black screen keep pressed both keys for 5 to 6 seconds then release power key Keep holding the home key until iTune detect it . Thats all --------------------------------------------------------- Best Regards GSM-DOCTOR Follow the rules i have to learn english |
12-30-2012, 09:22 | #14 (permalink) | |
which version of IOS you want to install???? --------------------------------------------------------- Best Regards GSM-DOCTOR Follow the rules i have to learn english | |
12-30-2012, 09:50 | #15 (permalink) | ||||
I was aslep Thanks guys for pointing it out you are life savors If you see the time of post you will get idea why and how i did mistake No need to get confused,I"m sorry i wrote a wrong line. Quote:
Thanks again Quote:
It will probably avoid host error"s Last edited by Sitlay KING; 12-30-2012 at 09:53. Reason: Adding reply :) | ||||
