12-21-2012, 20:16 | #4 (permalink) |
No Life Poster Join Date: Oct 2007 Location: P A K I S T A N
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | If you want downgrade then put device to PAWN DFU using iREB And restore to official 4.1 (only 3gs) Note: Error 6 means that device Not enter the downgrading mode, change USB port (the back one of chassis is better) and restart computer. --------------------------------------------------------- Best Regards GSM-DOCTOR Follow the rules |
12-21-2012, 20:21 | #5 (permalink) | ||
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | Quote:
12-21-2012, 20:28 | #6 (permalink) |
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | Thanks to CONCORDIA GSM which i posted is only for 3gs as i mentioned in brackets not for iphone4S or else. A5 devices have no downgrade solution till now even with SHSH saved --------------------------------------------------------- Best Regards GSM-DOCTOR Follow the rules |
12-21-2012, 21:31 | #9 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 320894 Status: Offline Thanks Meter: 7 | Device was Ergonomics normal ... I did a survey of the contents of the device occurred after standing problem on the iTunes device when giving restor show this problem The iPhone "iPhone could not be restored. An unknown error occured (6) |
12-21-2012, 22:09 | #13 (permalink) |
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | Bro already i told you that no downgrade for A5 iDevices even with SHSH saved. So don't waste your time and also the forum's space. --------------------------------------------------------- Best Regards GSM-DOCTOR Follow the rules |
12-21-2012, 22:17 | #15 (permalink) | |
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | Quote:
If you want a clean restore then you can do it but only IOS 6.0.1 no any other version only IOS 6.0.1 Just restore it and you will fix your phone if it has some software issues. Hope you understand --------------------------------------------------------- Best Regards GSM-DOCTOR Follow the rules | |
