12-25-2012, 05:07 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Iphone4 after restore can't "Get out of Recovery Mode" I have Iphone4 ios 6.0.1 after restore "can't get out of recovery mode" tryed: tynumbrelle Recboot ireb Not suceess Trying to jaibreak with ios5.1.1 and 6.0 all done bur in phone screen have this error " Error Reboot the device into normal operating mode. Then perform a clean slide to power off Then try redsn0w again" And when I put it on normal it's swith directly to recovery mode Please any idea Thanks Please |
12-25-2012, 05:35 | #2 (permalink) |
No Life Poster Join Date: May 2007 Location: Kolkata<<<India
Member: 505794 Status: Offline Sonork: 100.1627614 QQ:1958018248 Thanks Meter: 2,266 | Try to restore iOS 6.0.1 with latest iTunes.... Or change pc......... post result. Br, azam !!!! Simply the Best !!!! |
12-26-2012, 12:28 | #9 (permalink) |
Freak Poster Join Date: Aug 2009
Member: 1097251 Status: Offline Sonork: monk Thanks Meter: 13 | try this with error 14 post reply disconnect battery connector for a short while...reconnect and put your device in recovery mode...restore with the latest itunes and IOS 6.0.1, you should have a clean restore. NB.CONNECT IN RECOVERY MODE NOT DFU |
12-26-2012, 13:41 | #10 (permalink) | |
Freak Poster Join Date: Oct 2010 Location: in barcelona
Member: 1423754 Status: Offline Sonork: nighthing Thanks Meter: 23 | Quote:
03-06-2013, 03:40 | #11 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1894899 Status: Offline Sonork: H78 Thanks Meter: 0 | Try to put your iPhone 4 in DFU mode and then restore it. You can try these steps below: 1. Try another USB cord. 2. Restart your computer for a try. 3. Hold the power button, it might restart your iPhone. 4. Update your iTunes to the latest version. Plug in your iPhone. If iTunes can't recognize it, then in iTunes in the top left corner click help > run diagnostics. On the box that comes up, check the last two things. Click next and it should identify your iPhone and then restore it. |
01-03-2014, 05:02 | #12 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | If you did restore with latest version , restore Done So Check home button , If home button line is short , Its always go recovery Mode Br AzimBahar |
01-03-2014, 09:31 | #13 (permalink) |
No Life Poster Join Date: Apr 2012 Location: < Man is stronger than stone.>
Member: 1744389 Status: Offline Sonork: 100.1657056 Thanks Meter: 215 | if you have some unit of iphone 4, change logicboard, until you make restore. there no need customer to know that detail.. have job done, and sure,home buton will get you in recovery, logically. br |
02-26-2014, 03:55 | #14 (permalink) | |
Junior Member Join Date: Feb 2014
Member: 2135730 Status: Offline Sonork: http://sonork.com/eng/cli Thanks Meter: 0 | Quote:
If you have been backing up to iCloud choose that (be sure to plug your phone in to a wall charger as this will take hours to complete). If you haven't been backing up to iCloud choose restore from iTunes backup, then restore from the backup you created the last time you synced your phone. If it won't restore in recovery mode by connecting it to iTunes you will have to try putting it in DFU mode to restore it. | |
