07-10-2013, 11:21 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: P A K I S T A N
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | issues in Pakistan - Apple Activation , Restoring , Updates , Appstore ,iCloud some going wrong in Pakistan Tele Communication Authority (PTA) and apple service are not working properly at the moment so i have some alternative solutions to carry on your work Activation : You need another working phone to use as a Network Adopter 1: Put a Telenor Sim in a working another iPhone (IOS should be 6.1.3 or Later) 2: now go to setting and turn On Data Services (GPRS/EDGE) it sould have minimum 10 PKR balance 3: now go to settings >> General >> Mobile Data / Cellular >> Personal Hotspot>> and Turn it ON 4: now activate your unActivated iPhone with Hotspot Network (WIFI through the another working Iphone) Your phone will be activated in few seconds Enjoy...............!!! Updates/Restore : 1: Use Proxy or Simply Install Hotspot Shield or Alternative and try to Restore or Update and You will be Success Appstore / iCloud : use VPN (HOtspot Shield , VPN one Click ETC) in iPhone get signed in and downloads from Appstore or Use iCloud Regards GSM-DOCTOR Last edited by GSM-DOCTOR; 07-11-2013 at 10:02. |
The Following 6 Users Say Thank You to GSM-DOCTOR For This Useful Post: |
07-10-2013, 11:40 | #4 (permalink) | |
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | Quote:
http://forum.gsmhosting.com/vbb/f456...e-4-a-1685266/ http://forum.gsmhosting.com/vbb/f456...-down-1683988/ http://forum.gsmhosting.com/vbb/f456...ating-1685322/ | |
07-10-2013, 13:18 | #11 (permalink) |
No Life Poster Join Date: Feb 2012 Location: Pakistan
Member: 1726229 Status: Offline Thanks Meter: 223 | Iphone 3G error 1015 after restored now how solve? itunes hs detected an Iphone in recovry mode. you must restore this iPhone before it can used with itunes |
07-11-2013, 08:07 | #14 (permalink) |
No Life Poster Join Date: Jan 2008 Location: peshawar
Member: 668816 Status: Offline Sonork: no Thanks Meter: 182 | @GSM-DOCTOR! There is after Restore iphone not in normal mode.. so how to on hotspot by setting. when jailbreak it then not active with sim. |
The Following User Says Thank You to hussainafridi For This Useful Post: |
07-11-2013, 08:47 | #15 (permalink) | |
this is the big problem in you peoples that you can't read anything carefully here is it Activation : 1: Put a Telenor Sim in a working iPhone (IOS should be 6.1.3 or Later) 2: now go to setting and turn On Data Services (GPRS/EDGE) 3: now go to settings >> General >> Mobile Data / Cellular >> Personal Hotspot>> and Turn it ON 4: now activate your iPhone with Hotspot Network (WIFI through the working Iphone) Your phone will be activated in few seconds Enjoy...............!!! | |
