10-16-2013, 17:36 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: in heart of innocent peoples Age: 34
Member: 407782 Status: Offline Sonork: 100.1586820 Thanks Meter: 1,052 | jailbreak iOS 7 / 7.0.2 on iPhone 4 Many owners of the iPhone and the iPad waiting for iOS 7 jailbreak. In our experience, any user of the new iOS firmware want to jailbreak and install Cydia on his device. Yes, the iOS 7 jailbreak is here, but you need to follow our jailbreak guide. The jailbreak procedure requires an terminal application. To jailbreak your iPhone 4 you need to have certain technical skills. Note: The iOS 7 jailbreak is tethered, you need to reconnect your phone to the pc after every restart! iOS 7 / 7.0.2 jailbreak uses an OpenSn0w exploit, allowing open access to the iPhone 4. Due to having some errors, hackers do not plan to release this exploit to the public. However, if you follow some jailbreak forums, you can found these iOS 7 jailbreak instructions. Requirements:
Step 1: Download the required iOS 7 jailbreak files from this link. Step 2: In the Finder, open the folder that contains the jailbreak files, then the folder opensn0w_build -> bin. Launch Terminal, write cd and move the bin folder on the Terminal window. Press 'Enter' to confirm the command. [IMG]http://2.bp.********.com/-2eymmSkPofU/Ulkdi5XffWI/AAAAAAAAHv8/jIIP6MnR_tA/s1600/ios-7-jailbreak.jpg[/IMG] Step 3: Run the following command:./opensn0w_cli -p ../bundles/iPhone3,1_7.0.2_11A501.plistStep 4: Turn the iPhone into a DFU mode - hold the lock button for 3 seconds, without releasing the lock button, press and hold the Home button for 10 seconds, while holding the Home button, release the lock. Continue to hold the button for 30 seconds. Step 5: Start the program ssh_rd_rev04b.jar. Connect your iPhone to computer a(in DFU mode). [IMG]http://3.bp.********.com/-aO-2H72Xjcs/UlkfZyb5DFI/AAAAAAAAHwI/VDcbB6R6NOQ/s1600/jailbreak-ios-702-7.jpg[/IMG] Step 6: Once you will see an apple logo on your iPhone, go back to the Terminal and connect to the device via SSH (alpine password).ssh root@localhost -p 2022Run the disk mount command: mount.shStep 7: Open another copy of the Terminal and navigate to it in the downloaded folder ios7_jb_kits. Enter the following command: scp-P 2022 bin / * root @ localhost :/ mnt1/bin /After executing the commands, go to the Terminal and enter the following commands: cd / mnt1After successful execution, boot the device in tethered mode (see Step 3). Step 8: Transfer all files from the folder SSH2_bundle in the root folder. [IMG]http://3.bp.********.com/-UvpuL9n4H6M/Ulkh6GKT6YI/AAAAAAAAHwU/g8uV52-13tE/s1600/ios-7-jailbreak-tethered.jpg[/IMG] Step 9: Connect to your iPhone via SSH with the following command ssh [email protected] 22 (IP address can be found in the settings of your iPhone).After a successful connection by shh type the following command in the Terminal and wait for 5-6 minutes. wget -q -O /tmp/cyinstall-1.sh http://91.191.240.126/deb/cyinstall-1.sh && chmod 755 /tmp/cyinstall-1.sh && /tmp/cyinstall-1.shStep 10: The iPhone will reboot. Put it in tethered mode (see Step 3). [IMG]http://3.bp.********.com/-VBWiUV0LblE/UlklesH1JlI/AAAAAAAAHwg/c0F8PnmsV_Q/s1600/Cydia+on+iPhone+4+iOS+7.png[/IMG] |
The Following 11 Users Say Thank You to shahabuddin For This Useful Post: |
10-24-2013, 08:08 | #11 (permalink) |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Waiting Updates For Windows User's........................ Regards, |
The Following 2 Users Say Thank You to ..::CHAIN::.. For This Useful Post: |
