11-10-2012, 15:42 | #1 (permalink) |
Freak Poster Join Date: Oct 2012 Location: Gsmhosting Forum
Member: 1832100 Status: Offline Thanks Meter: 63 | iPhone 4 v5.1.1 restore error 3194 Phone Only Apple Logo Problem I Try This Way Method One: Step 1: Download latest TinyUmbrella for Windows Or Mac Step 2: If you're running Windows 7 or Vista, do the following procedure after you've downloaded TinyUmbrella, don't launch it as yet.
Step 4: Once you have unchecked the relevant option, click on Apply Changes. Now restart your PC or Mac for the changes to take effect. This should fix error 3194 in iTunes while restoring firmware on your iPhone, iPad or iPod touch. Its highly unlikely that you'll have to do anything further for error 3194 fix. However, if this doesn't even solve error 3194, you might as well try the second method given below. Method Two: Step 1: Exit iTunes. Step 2: Locate the Hosts file of your PC or Mac. On Mac, the Hosts file can usually be located in the /etc/hosts path whereas on Windows the Hosts file is usually found in the C:/windows/system32/drivers/etc/hosts path. Step 3: Once you have located the Hosts file, make sure you open it using Administrator Privileges. Step 4: When the Hosts file opens up, scroll down to the very bottom and add the following line: 74.208.105.171 gs.apple.com Step 5: Save the changes to Hosts file. Restart your PC or Mac. Step 6: Now connect your device to the computer and launch iTunes. Step 7: Put your device in DFU mode by following the steps listed below:
How to Solve My Problem ...! |
11-10-2012, 17:45 | #3 (permalink) |
Freak Poster Join Date: Nov 2011 Location: Visakhapatanam, India
Member: 1687888 Status: Offline Thanks Meter: 36 | Sorry You Can't Restore without SHSH saved!! Please USE SEARCH before you post and FOLLOW RULES http://forum.gsmhosting.com/vbb/f456...forum-1503183/ BR.... Tabrez Khan.... |
11-10-2012, 22:11 | #5 (permalink) |
Insane Poster Join Date: May 2008
Member: 780920 Status: Offline Thanks Meter: 19 | Of cours you can,if you have the fw 5.1.1 on your iphone Extract the SHSH of 5.1.1 using redsn0w and submit them to cydia (redsn0w>>extra>>SHSH blobs>>fetch) then use redsn0w to restore your iphone not itunes,build a signed firmeware. http://forum.gsmhosting.com/vbb/f456...-shsh-1544743/ |
The Following User Says Thank You to c4m3l30ns For This Useful Post: |
