12-25-2012, 11:46 | #1 (permalink) | |
No Life Poster Join Date: May 2007 Location: Kolkata<<<India
Member: 505794 Status: Offline Sonork: 100.1627614 QQ:1958018248 Thanks Meter: 2,266 | [Tutorial]..::How to Install .deb File [iPhone/iPod/iPad]::.. How to install .deb file on your iPhone/iPad/iPod _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ 4 Methods to install a .deb file into your iOS, choose the easier for you! ----------------------------------------- 1st Method: Install with iOS Safari Browser + iFile Requirements: iPhone/iPod/iPad Safari Browser + iFile Download .deb file with iPhone/iPod/iPad Safari browser Choose >> Open in “iFile” Once iFile opens >> Select Installer Respring YOU ARE DONE -------------------------------------- 2nd Method: Install with SSH Client + iFile Requirements: SSH Client (iFunbox for Windows/Cyberduck for MacOS) + iFile Download iFunbox >> (i-FunBox v2.1 | File Manager, Browser, Explorer, Transfer Tool for iPhone, iPad & iPod) Windows , or Cyberduck for MacOS Download desired (.deb) file to your desktop Run iFunbox and connect your iOS (iPhone, iPod or iPad) iFunBox will show your device contents, Now navigate to any folder for example: var/mobile/Documents Move (.deb) file from your desktop to var/mobile/Documents Run iFile from your iOS, and navigate to the same folder i.e. var/mobile/Documents Click on (.deb) file and select install YOU ARE DONE. TIP : I can not SSH into my iPhone/iPod/iPad! -------------------------------------------- [LIST] I can not find var/root? I can not SSH into my iPhone/iPad? I have jailbroken device, my SSH client is discovering my iPhone/iPad as (JAILED)? >> Install OpenSSH from Cydia, reboot, then try again. >> If you still having problems>> Install afc2add from Cydia then reboot. ----------------------------------------------- 3rd Method: AutoInstallation Folder Requirements: SSH Client (iFunbox for Windows/Cyberduck for MacOS) Download iFunbox >> (i-FunBox v2.1 | File Manager, Browser, Explorer, Transfer Tool for iPhone, iPad & iPod) Windows , or Cyberduck for MacOS Download desired (.deb) file to your desktop Run iFunbox and connect your iOS (iPhone, iPod or iPad) iFunBox will show your device contents, Now navigate to var/root/Media/ Create the folder Cydia/AutoInstall (if not already created) Move (.deb) file from your desktop to var/root/Media/Cydia/AutoInstall Reboot your iOS YOU ARE DONE -------------------------------------------- 4th Method: Install with Mobile Terminal Requirements: Mobile Terminal + OpenSSH “Steps 2 and 3 are only if you have never installed a .deb file with this method” Download the .deb file you want (example : LockInfo) Start Cydia, go to “Search”, type “Mobile Terminal” and install it Repeat step 2 for “OpenSSH” Start “MobileTerminal” Type the following commands , then reboot: Quote:
press button Br, azam !!!! Simply The Best !!!! Last edited by ..::Nokian CareŽ::..; 12-25-2012 at 11:50. Reason: modify | |
The Following User Says Thank You to ..::Nokian CareŽ::.. For This Useful Post: |
