Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
03-19-2010, 06:36 | #16 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Barisal Age: 44
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | auto power on,key hang complete sol.for ZTC ZT6668 AFTER INSERTING BATTERY SET AUTO POWER ON THEN ONLY REMOVE THIS D50 TRANSISTOR UR PROB. WILL BE SOLVED. POST RESULTS & DON'T FORGET TO SAY THANKS |
The Following 29 Users Say Thank You to Dooha_Bd For This Useful Post: |
03-19-2010, 06:53 | #17 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | MAKING OF CHARGER or bad contact FOR CHINESE PHONES MAKING OF CHARGER or bad contact FOR CHINESE PHONES MAKING OF CHARGER or bad contact FOR CHINESE PHONES THIS MAIN PROBLEM IS WHEN U CHANGE UR CHARGER. IN ANY CHARGER OPEN UR CHARGER'S CHARGING CONNECTOR THEN REMOVE THE WIRES FROM CONNECTOR. RED,BLACK,GREEN,WHITE REMOVE RED & BLACK WIRE. CONNECT CHARGER WITH PHONE REMOVE BATTERY SEE - & + OF PHONE CHECK NEGATIVE CONTINUTY WITH MULTIMETER TO THE CHARGER CONNECTOR POINTS SOLDER BLACK WIRE TO NEGATIVE TRACED SOMETIMES IN SOME SETS POSITIVE IS ALSO GIVING CONTINUTY U CAN ATTACH RED WIRE. THE VOLTAGE IS OK BUT IT WILL NOT DISPLAY CHARGING THEN U HAVE TO TEST BY INSERTING BATTERY TO THE PHONE BY ANY WIRE OR TWIZER CONNECT ONE SIDE TO RED WIRE CONNECTED TO THE POINT THEN SHORT OTHERPINS ONE BY ONE BY THIS WIRE.UR PROBLEM IS SOLVED IN BAD CONTACT CHARGER PROB. U JUST HAVE TO TEST RED WIRE TO OTHER POINTS. I TRIED THIS MANY TIMES 100% SOL. THANKS POST RESULTS NOTE:- THIS PIC IS ONLY AN EXAMPLE TO TELL LIKE THIS TO DO THIS JOB. |
The Following 25 Users Say Thank You to Dooha_Bd For This Useful Post: |
03-19-2010, 08:13 | #18 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Hlash fil========= HLASH FIL========= TECNO-BIG DOWNLOAD LINK------- 4shared.com - online file sharing and storage - download TECNO.bin FOR SPIDERMEN SOPPORTED DONOT FORGET OT PRESS THANKS |
The Following 18 Users Say Thank You to Dooha_Bd For This Useful Post: |
03-19-2010, 08:20 | #19 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | 5310 ring solution 5310 ring solution DONOT FOR GET TO PRESS THANKS |
The Following 32 Users Say Thank You to Dooha_Bd For This Useful Post: |
03-19-2010, 08:23 | #20 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | China 6300 restart-------- CHINA 6300 RESTART-------- USE ONLY THANKS |
The Following 21 Users Say Thank You to Dooha_Bd For This Useful Post: |
03-19-2010, 08:51 | #21 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | China ringer ic alternet........... CHINA RINGER IC ALTERNET........... 9 BALL CRYSTAL RINGER IC ALTERNET (NOT ONLY CHINA MOBILE BUT ALSO OTHER MOBILE TOO) press only thanks |
The Following 30 Users Say Thank You to Dooha_Bd For This Useful Post: |
03-19-2010, 09:43 | #22 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | chinese phones with second sim problem. chinese phones with second sim problem. DONOT FORGET TO PRESS THANKS |
The Following 40 Users Say Thank You to Dooha_Bd For This Useful Post: |
03-19-2010, 14:28 | #23 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Uploading usually costs a lot of time clicking on the THANKS button only 2 seconds.So Be as fair and give THANKS to the uploader |
The Following 23 Users Say Thank You to Dooha_Bd For This Useful Post: |
03-20-2010, 05:37 | #24 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Flash fil------------ Bluetooth-5310 DOWMLOAD LINK-- 4shared.com - online file sharing and storage - download Bluetooth-5310.rar PRESS ONLY THANKS |
The Following 20 Users Say Thank You to Dooha_Bd For This Useful Post: |
03-20-2010, 05:43 | #25 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Flash fil--------- T-331 Download Link: World's Leading Image,Video,Audio and Document Sharing Portal DONOT FORGET TO PRESS THANKS |
The Following 22 Users Say Thank You to Dooha_Bd For This Useful Post: |
03-20-2010, 13:25 | #27 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | BIRD V750 MIC Solution BIRD V750 MIC Solution if this post is healpfull to you-press only thanks |
03-21-2010, 05:04 | #28 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Niktel c,8000 insert sim NIKTEL C,8000 INSERT SIM DO NOT FORGET TO PRES THANKS |
The Following 28 Users Say Thank You to Dooha_Bd For This Useful Post: |
03-21-2010, 05:19 | #29 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Mobile-Phone-SIGMATEL-S3- Mobile-Phone-SIGMATEL-S3- DOWNLOAD===== https://forum.gsmhosting.com/vbb/RapidShare: 1-CLICK Web hosting - Easy Filehosting SUPPORTED BOX-Box Spiderman |
The Following 13 Users Say Thank You to Dooha_Bd For This Useful Post: |
03-21-2010, 05:27 | #30 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | flash file n79 DOWNLOAD==== download:2shared - download GFIVE N7...______________ SUPPORTED BOX-------SPIDER MEN |
ALL CHINESE MOBILE SOFTWARE AND HARDWARE 100% solution | gopalhot | Chinese Models & Cloned Phones | 587 | 11-23-2011 13:27 |
