CECT T689,restarting 1 Attachment(s) I have CECT T689,and when I put sim inside phone is restarting,again and again,e.t.c.I try to restore factory,but it's the same.Maybe is hardware,because phone is not restarting without sim inside. |
read backup file flash then forma good luck SE |
manul format by 1122 |
BR SE |
HOw can I format? GOw can I format this phoen,and with waht I can create buckap,and then format?I try with reset with 1122,but it's the same....Please help me |
hello bro Format ffs This is pinout for you data cable Cect-T689 keyboard top, connector_1x12_mini 6: Tx 7: Rx 12: Gnd [email protected] |
ok,but.. Ok,I wil make a cabel,but program to read flash and flash file,where I can find? Tx |
Tx,but I have allready download this mtk tool,but I don't have flash files,and please explain how to make a cable.YOu give me the pinout,but on wich type of cable(rj45,rs232,)and wich box I must use.Tx |
I think Mtk-Box will help you. |
*** read flash backup be4 format ur fone **** *** if ur fone CPU is MT6226BA DONT WRITE FLASH IF NOT UR FONE DAED BR SE |
infinity box is best for repair this phone...only select cect t689 and press ffs(format ffs) |
i thinks you need format with BOX( MTK, INFI , tIANMU,) if not oki . you try to flash the phone . i think your phone will be OK ! goodluck . |
This is the proove : COM14 [VCP3] selected Device: Autodetect Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished memory structure: 2nd [enhanced] (or higher) generation warning: make backup before any action ! identification data Ok identification data backup saved: id.E3ED9EA7.[E550_A5ARABBT_E550_GPRS_MT6226_S01.PCBV3_0_01_2.BI N_22F6193A].rpl identification detection finished device-id: E3ED9EA7 protocol version: 04 version sw1: E550_A5ARABBT_E550_GPRS_MT6226_S01.PCBV3_0_01_2.BI N version sw2: E550_A5ARABBT.PCBV3_0.01.2 ffs offset/size: 00800000/001FF000 detecting eeprom area in 1 chip(s)... flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area detected[00000000]: 00E00000-00FFFFFF detecting structure pass 1... ................... detect standard location pass #1... .................................................. ...... detect extended location pass #1... .................................................. . detect standard offset pass #1... detect standard data... layout detection complete eeprom element #1 detected ok reading [eeprom[E550_A5ARABBT_E550_GPRS_MT6226_S01.PCBV3_0_01_2.BI N]]... file saved: backup_eeprom[E550_A5ARABBT_E550_GPRS_MT6226_S01.PCBV3_0_01_2.BI N]_20070921-145819.B0E.bin flash: EC257E25082501:29EA0000000000 Check space Done Manipulation... detection procedure, wait... detection procedure completed Manipulation Done Finalization... Finalization Done Write... flash: EC257E25082501:29EA0000000000 Write: eeprom Write Done file saved: backup_system_log_E3ED9EA7_[E550_A5ARABBT_E550_GPRS_MT6226_S01.PCBV3_0_01_2.BI N]_22F6193A_20070921-145856.B0X.bin Finished, time used: 208 sec Remove/Install battery now ! COM14 [VCP3] selected Device: Autodetect Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished memory structure: 2nd [enhanced] (or higher) generation warning: make backup before any action ! identification data Ok identification data backup saved: id.E3ED9EA7.[E550_A5ARABBT_E550_GPRS_MT6226_S01.PCBV3_0_01_2.BI N_22F6193A].rpl identification detection finished device-id: E3ED9EA7 protocol version: 04 version sw1: E550_A5ARABBT_E550_GPRS_MT6226_S01.PCBV3_0_01_2.BI N version sw2: E550_A5ARABBT.PCBV3_0.01.2 ffs offset/size: 00800000/001FF000 detecting eeprom area in 1 chip(s)... flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area detected[00000000]: 00E00000-00FFFFFF detecting structure pass 1... ................... detect standard location pass #1... .................................................. ...... detect extended location pass #1... .................................................. . detect standard offset pass #1... detect standard data... layout detection complete eeprom element #1 detected ok reading [eeprom[E550_A5ARABBT_E550_GPRS_MT6226_S01.PCBV3_0_01_2.BI N]]... file saved: backup_eeprom[E550_A5ARABBT_E550_GPRS_MT6226_S01.PCBV3_0_01_2.BI N]_20070921-145819.B0E.bin flash: EC257E25082501:29EA0000000000 Check space Done Manipulation... detection procedure, wait... detection procedure completed Manipulation Done Finalization... Finalization Done Write... flash: EC257E25082501:29EA0000000000 Write: eeprom Write Done file saved: backup_system_log_E3ED9EA7_[E550_A5ARABBT_E550_GPRS_MT6226_S01.PCBV3_0_01_2.BI N]_22F6193A_20070921-145856.B0X.bin Finished, time used: 208 sec Remove/Install battery now ! |
