Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
08-19-2009, 17:52 | #1 (permalink) |
Junior Member Join Date: Dec 2007
Member: 644415 Status: Offline Thanks Meter: 0 | i9 engineer menu - now phone wont power on I have just gone into the engineering menu using # codes from here. I was just looking at the settings but managed to select an option (the option said something like High Speed SIM) the phone immediately powered off and now wont switch on. I have I bricked the phone. Can it be recovered if so, does anyone know how? Thanks |
08-19-2009, 19:17 | #2 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1069453 Status: Offline Thanks Meter: 9 | yes, it can be recovered. You need a flash-cable and i think you need to format the userspace. in anycase make a Backup before. |
The Following User Says Thank You to Loonix For This Useful Post: |
08-19-2009, 23:50 | #3 (permalink) | |
Member: 644415 Status: Offline Thanks Meter: 0 | Quote:
If I can't get one local can I make a serial cable? or does it need some circuit in it to run with software? | |
08-21-2009, 19:52 | #4 (permalink) |
Member: 1069453 Status: Offline Thanks Meter: 9 | No, i dont know any shops in the UK, , i bought mine from mysciphoneshop.com and it came from newzeeland and took about a month to arrive. If you want to build a cable you need a RS232 to TTL adapter, so yes it is a bit more then a simple cable. |
08-21-2009, 20:29 | #5 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Rawalpindi, Pakistan
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | Quote:
I will try to guide to get proper cable. | |
The Following User Says Thank You to Umair Rashid For This Useful Post: |
08-26-2009, 13:01 | #6 (permalink) | |
Phone doesn't power on. I purchased the phone from HK but live in UK so ideally I am looking to get or make the cable locally. Thanks | |
08-26-2009, 17:48 | #7 (permalink) |
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | U need proper equipment such as a flasher box in order to repair Ur phone's software. Without box it's impossible.... |
08-26-2009, 19:07 | #8 (permalink) | |
Junior Member Join Date: Aug 2009
Member: 1099606 Status: Offline Thanks Meter: 1 | Quote:
I am reading another post about flashing the phone. I thought you can build the cable and use some software app to flash the phone. http://forum.gsmhosting.com/vbb/showthread.php?t=808858 Maybe I don't know enough. Correct me if I am wrong. | |
08-26-2009, 23:04 | #9 (permalink) |
Member: 1069453 Status: Offline Thanks Meter: 9 | Hi I experimantaly bricked my own i68+ with highspeed sim. all you need to do to fix it is fo format the FAT part of the firmware or to restore an earlier backup. You dont need a box to do it but it helps you can use many MTK flashtools with which i did it or spiderman versions that dont use a box. |
Nokia 6288 Software Updater Failed Now Wont Power On | Stokbroka | Nokia Base Band 5 ( BB-5 ) | 5 | 06-02-2008 11:35 |
sony/eric w600i...took it apart, now it wont turn on. | coolmacd | Sony Ericsson Hardware Repair | 0 | 12-26-2007 21:59 |
I unlocked a phone and now it wont power on. | aarons6 | VygisToolbox | 12 | 11-17-2006 01:26 |
Flash failed Now V3 Wont Power Up | mbcommunication | Smart-Clip | 8 | 04-11-2006 12:50 |
help tried to flash phone now it wont switch on?? | budget | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 12-13-2001 19:31 |
