Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
![]() | #421 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2007 Location: USA
Member: 519462 Status: Offline Sonork: 100.1644791 Thanks Meter: 35 | please flash file need XUBO35_09A_GEMINI_PCB01_GPRS_MT6235B_S01.K500_4665 1112_31111_R2_3.BIN please flash file need this phone MAXX MS830 chines forums MALATA K500 |
![]() | #422 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Feb 2010
Member: 1246940 Status: Offline Thanks Meter: 3 | need flash file rage turbo model Chip=SpreadTrum Action=ReadFlash FlashType=NOR boot=6600L/WT6226-COM Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 FlashFile=ra Comport=COM12 Baudrate=921600 CPU_Type=SC6600L7A CPU_ID=66007019 NOR_ID=002088C0002088C0 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064HU NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.3.2.7 It is sensing the pinout fast... RXD=4 TXD=3 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600701900006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7A Flash: NOR_ST_M58WR064HU setting the Flash Parameters... Settings have been completed! Reading Flash... Saved file to: ra All Done. Reading Project Version... Platform Version: MOCOR_09A.W10.25.16.03_Release Project Version: SC6600L_sp6601l MMI Version: 3067_JY01_QVGA_FT200_RAGE_Y97_BT_FM_SC_SR1_V03_201 11104_1454 BASE Version: BASE_W09.20_P42.9.1 HW Version: 3067 Project Bulid Time: 11-9-2011 17:13:20 SVN:3014-Mixed-SVN:No |
![]() | #423 (permalink) |
Moderator ![]() Join Date: Nov 2009 Location: €urope Age: 42
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,165 | Walton B200 W008_PCB01_GPRS_MT6223_S00.W008-K1_A01_20101020.BIN >>>Click Here<<< Bro:- Palash Ahammad |
The Following 2 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
![]() | #425 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,165 | ![]() Walton C30 W306_PCB01_GPRS_MT6253_S00.W306-K1_A05_20101230.BIN ![]() >>>Click Here<<< Bro:- Palash Ahammad |
![]() | #426 (permalink) |
Junior Member ![]() Join Date: Nov 2011
Member: 1682690 Status: Offline Thanks Meter: 0 | karbonn kc 455 pls if so i need flash file of karbonn kc555 16 mb flash file MT6226_TC58FVM7TDD_20120509170338 it is triple sim phone but for gsm no network insert sim it is showing but in same slot cdma sim is working fine best regards |
![]() | #428 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2011 Location: all device sell hear
Member: 1627323 Status: Offline Sonork: WhatsApp+8801763009154 Thanks Meter: 481 ![]() | help me plz ![]() Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=4 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EC225400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: L5PEB02.9.52.1.0T03M0305_M716 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00700000, size=0x00100000 All Done micromax x210 |
![]() | #429 (permalink) |
Junior Member Join Date: Jun 2012
Member: 1775881 Status: Offline Thanks Meter: 0 | Android tv box, PCB says mdp005h, Also known as : JESURUN J03 1080P Linux 2 6 x Android 2 2 Network stuck at boot, need new firmware to flash? |
![]() | #432 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2005 Location: EL-BALOUTE Age: 48
Member: 168513 Status: Offline Thanks Meter: 838 | HI all ... need this flash: GKOOL Model:Q1 CPU 6253.this is log: Code: Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098009E00000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: T001_Gaoshang_V83 thanks. ![]() ![]() ![]() |
![]() | #434 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2012 Location: Odisha India
Member: 1770085 Status: Offline Sonork: 100.1639467 Thanks Meter: 43 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=MT6235 CPU_ID=00000003 NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=00AD007600AD0076 NAND_Size=64MB NAND_Name=[HYNIX] HY27XS08121M Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6235, HardwareVer:8A01, SoftwareVer:8A04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 00AD007600AD0076 Read Hardware Information is done. Config EMI(Nor Flash only)... Failed to check H/W. Get Project ID from phone... Project ID: h737h_r_WIFI1__V1.04 i need this nand flash file its important please help me it is the file of tv mobile t10 which is specified wifi tv java screen touch mobile |
![]() | #435 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2009 Location: Bagerhat Age: 36
Member: 1188409 Status: Offline Sonork: 100.1616589 Thanks Meter: 276 | sigma tel fxd MTK_ROMINFO_v04HUIYUE25_GEMINI_PCB01_GPRS_MT6225_S 00.6302_C37C_ALX_S39_ML_A_1_V05.BIN help me i need this file |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
