Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
10-27-2008, 16:29 | #1 (permalink) |
Junior Member Join Date: Oct 2008
Member: 886386 Status: Offline Thanks Meter: 0 | Usb cable for i68+sciphone. Just bought one new version i68+sciphone and the usb cable is wrong ,try to contact the seller but get no luck for that . So i have been looking online but i can only find for old i68 and say that i will not work with the new version . Can someone tell me where to get that usb cable...thank you in advance. |
11-05-2008, 18:34 | #2 (permalink) |
Member: 876227 Status: Offline Thanks Meter: 5 | Are you sure what you phone really is? There are clones of clones out there. Then there is one actual sciphone version of the I68+ that physically has an I9 board inside but is flashed with the I68+ Version: 2.0 Build date: 9/15 firmware (like mine).This was done due to mfg board shortage. You can also tell by what color the dialed digits are. White digits = normal board Colored digits = I9 board. The reason I mention this is because I read that the the phone connectors are different between the two. This may be your problem. DMARSTELLAR on the P168 Forum ran into the same problem as you seem to have. What is your version? If you don't know, from the keypad enter *#8375# (Press dial or send key if it doesn't show display after entering #) Should display something similar: [VERSION] LS_I68_62025_128_A_V2.0 [BRANCH]: 62025 TELSDA25_07B BUILD: BUILD_NO SERIAL#: 0915xxxxxxx 10 [BUILD TIME] 2008/09/15 00:47 My connector appears to be a L12C 1x12 pin connector. Dredyns |
11-09-2008, 17:11 | #3 (permalink) |
Junior Member Join Date: Nov 2008
Member: 896698 Status: Offline Thanks Meter: 0 | Hi guys. I just picked up the [hone couple of days ago. Box says new version.. phone says i68+ but... my version does not match what you have. Its with the i9 motherboard (colored numbers when dialing) also I noticed somethind wrong in its Build. [VERSION] LS_i68_62025_64_A_V1.0 [BRANCH]: 62025 TELSDA25_07B BUILD: BUILD_NO SERIAL#:1020010XXXX 10 [BUILD TIME] 2008/09/15 00:53 Did I get a phony upgraded version of the sciphone? Its got the shake function but not the option to turn it off. |
11-13-2008, 15:57 | #5 (permalink) |
Member: 876227 Status: Offline Thanks Meter: 5 | No, not as far as I know. The HiPhone will let you mod the usb cable to flash by connecting pin 12 to pin 4 at the phone connector end of cable (also a L12C), but I believe it is a spread spectum processor not MTK like ours. I'm working on the cable to flash. I just received my order for the L12C connectors and verified they are indeed the right ones for my version of the Sciphone I68+(colored digits). I will be testing for Rx/Tx so I can mod one of my flash cables. There are people out there that can already tell us this, but they will not share info. I can only think it must be a greed issue with them. |
11-14-2008, 19:18 | #6 (permalink) | |
Insane Poster Join Date: Jun 2008
Member: 792296 Status: Offline Thanks Meter: 39 | Quote:
Yep, a BIG greed issue and a lot of BS involved, if you ask me!! | |
11-14-2008, 22:06 | #7 (permalink) |
Member: 896698 Status: Offline Thanks Meter: 0 | Thats sad. There are some people out there with the version 2 or higher on their phones.. it be great if they would flash their phone for a copy to help guys like my version 1 to update and really enjoy this phone. I dont have the touch flow menu like I was expecting.. Im not even sure if this program version will let me run 8gigs like the i68+ are supposed to. Oh and a bug I discovered while texting. Once the inbox got full it really started acting weird. I had to recalibrate the screen at least 4 times with resets following the recalibrating to get it working right. Otherwise I couldnt use the menu correctly or anything! Dont let it reach 100 text messages |
iPmart BX Series Cable Compatible For DKU2 / Mini & Micro USB Cable For Nokia Phone | IPMART | ipmart WebShop | 0 | 01-12-2010 13:20 |
flash cable for i68+ v1.0 | maniloti | Chinese Models & Cloned Phones | 0 | 11-23-2008 19:37 |
AV Cable with USB Cable for iPhone (7 in 1) - Original | IPMART | ipmart WebShop | 0 | 11-20-2008 09:50 |
How to install apps and games for I68+sciphone. | jasonle3315 | Chinese Models & Cloned Phones | 0 | 10-30-2008 20:58 |
