PadFinder box Smart universal box for Chinese phones ( for all phones ) with automatic pinouts search functions. |
07-24-2008, 12:52 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Age: 44
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | I have activated chinese cocktail soft, how to use it with main tool? So your first step is correct conection phone to box - connect your padfinder box to usb cable and to PC ( your box will be in "Unibox mode" ) - connect phone to correct cable ( Pad*** name ) - plug this cable into DB26 cable and connect it all to box - connect power wires from DB26 to battery contacts on phone ( if you connect it wrong "-" to "+" for example you will see blinking red light on the box, that mean you have to connect it correct - but most important there will be no any problem for your phone or box - WE MADE ALREADY a protection from it ) IMPORTANT: always use power wires - NO NEED TO USE BATTERY otherways you will get wrong pins Here is the picture how all must be connected: After than you can run soft - "main tool" When "Main tool" will be started your box mode must be automaticly changed to "command mode" But if this not happens and you will see error message about mode like on the picture bellow: You need to check your box mode - so just check if led "red" changed color to "yellow" and if changed alread just press "OK" on message windows. If your box still in "Unibox mode" than change it manualy to "command mode" with pressing and holding about 3 seconds "mode select botton". You will see that your box will be changed manualy to "command mode" than press in message windows "OK" botton and software will start! So, you will see next windows - I will not describe it agine what is main tool etc... you can find all info about about this tool there: http://www.padfinder.net/faq_article.php?article=87 So now we need now find correct pinout for our phone. 1. Phone is connected - we need to choose phone platform in my case is MTK ( code *#0044# call will change language to english - that mean is MTK based phone ) 2. Need to select correct cable ( in my case is Pad021 ) 3. So now press "search botton" and press power on botton on phone and hold it untill process will not stop. 4. So we got it pin That was shot description of this procedure - if you need more info about pin search check link bellow: How can the manual pinout selection be usefull? PadFinder pinout detection procedure Automatic pinout detection: Troubleshooting So after we got a pinout we need run chinese cocktail tool, BUT before we will run soft we need switch box to "Unibox" mode. It can be done by pressing the botton "Unibox mode" So now close Main tool ( after closing your box can be automaticly switched to unibox mode ) So now we have to run Chinese cocktail tool. When tool will be started your box mode must be automaticly changed to "command mode" You will see next windows: IMPORTANT: if bottons on software is not hoghlited - that mean you have no activations for this soft and you need buy activation, here is more info about it: http://www.padfinder.net/full_version.htm Our box very smart is not like other boxes in the market - our box store inside the memory last founded pins ad you can see on picture: RX-5 and TX-5, we need just select our cable type ( PAD 021 ) IMPORTANT: our PAdFinder box always store inside him memory last founded pinout even after usb reconect it will be stored So cable selected, pins we find out already now we need try to connect phone with soft. Press "Connect" botton on soft and press and hold power on botton on phone until software will not show you full info about phone. ( phone stay in same conection like it was used with "main tool", I mean need to use power wires connected to battery contacts!!! NO NEED TO USE BATTERY from phone ) That all, phone is connected and now you can manage it. I am not givin there info about Chinese cocktail tool, how to flash or unlock etc... there already described in support docs: How to repair Chinese phones with problems like "not power on/reboot/restart.. etc" How to change IMEI in Chinese phones? Chinese cocktail tool. Full software discription. Best tool for china made phones! |
The Following 2 Users Say Thank You to GSMtricks For This Useful Post: |
I have activated chinese cocktail soft, how to use it with main tool? | GSMtricks | PadFinder box | 14 | 01-31-2009 17:41 |
Help me I had UFS-3 + HWK but it clone So How to use it and how to active my box | dvdaio | UFS2 + UFS3-Tornadoflasher | 0 | 05-23-2007 21:27 |
phoenix program how to use it withe mt | aukonline | MT-BOX | 0 | 07-11-2006 15:00 |
phoenix program how to use it withe mt | speed08 | MT-BOX | 2 | 04-06-2006 06:01 |
