Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Multi-Box TEAM Products > PadFinder box
PadFinder box Smart universal box for Chinese phones ( for all phones ) with automatic pinouts search functions.
Old 06-21-2008, 19:20   #1 (permalink)
Member: 763939
Padfinder not detected
Dear all,
when i connect padfinder to my computer, it will detected the device as FTDI FT8U2XX Device but it show here in this site it shoud show in device manager as Padfinder COM Port (in Universal Serial Bus) and Padfinder USB Serial Port (in Ports).
Please can some budy explain to me what should i do to solve this problem?
* Also i download the driver for Multi Box and i force it to take drivers as below
USB Serial Converter Ver 2.4.6.0 (in Universal Serial Bus) and
USB Serial Port (inPorts)
but when i run PadFinder_MainTool_v1.7 it show PADfinder not Decected.
BR,
Naser M.
Old 06-21-2008, 20:31   #2 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
Change box mode manualy
The Following User Says Thank You to GSMtricks For This Useful Post:
Old 06-21-2008, 23:27   #3 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
download latest version 1.10 pinfinder & try it i hope work fine
The Following User Says Thank You to debmobile For This Useful Post:
Old 06-22-2008, 11:02   #4 (permalink)
Member: 763939
thank you GSMtricks, but how can i change to manual mode, because i press the button for long time while box connected to USB and no change happend.
is there other way to change the mode to manual mode?
Old 06-22-2008, 11:04   #5 (permalink)
Member: 763939
Thank you mov009, from where can i get this version?
Old 06-22-2008, 13:12   #6 (permalink)
Member: 137181
Thanks Meter: 3
uninstall previous drivers,restart pc,
then re insert usb cable
then install again device drivers
check device manager if successfully installed and check where com settings are in for padfinder com port if you want to change it change it into lower comport settings
then try to run the maintool program
see if it works
regards
swensonb
PADFinder User
Old 06-22-2008, 13:21   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,068
its hardware problem. send it beack to your reseller for warranty.
Old 06-22-2008, 17:32   #8 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
There already at support zone all video how to do. Check them please
Old 06-22-2008, 18:37   #9 (permalink)
Member: 763939
Dear GSMtricks, i already see all this videos but still not solving my problem.
what should i do to go to manual mode in steps please, maybe this will solve the problem.
BR,
Naser M.
Old 06-22-2008, 18:40   #10 (permalink)
Member: 763939
Dear Sir,
I try what you said but still problem available not solved.
please if you have any other solution can help me in this.
BR,
Naser M.
see if it works
regards
swensonb
PADFinder User
Old 06-22-2008, 18:47   #11 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
BR,
Naser M.
In support video already all info how to swith to other mode. Just check it
Old 06-23-2008, 10:06   #12 (permalink)
Member: 763939
Dear GSMtricks, i see all videos but still no luck to solve my problem.
still same message PADFinder not detected.
please if you cane guide me step by step to let this unit run i try all possibilities in this but no succeed and i will attach you the driver photo from device manager to see if it is right or wrong (how can i attach image for you)
Old 06-23-2008, 14:59   #13 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
But all is already written bro. I cannot guide you more.. If box still not working - contact your reseller
PadFinder pinout detection procedure GSMtricks PadFinder box 12 09-22-2009 18:45
Padfinder box not detected … MGPhotos PadFinder box 9 06-11-2008 08:44
box cannot detected smartcard not detected GUDO-GSM Infinity-Box 6 10-25-2007 12:48
Page generated in 0.17525 seconds with 9 queries
