07-18-2008, 10:13 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: sn,fdo,lu philippines
Member: 288470 Status: Offline Sonork: 100.1605122 Thanks Meter: 664 | >>> another K800i gdfs damaged successfully repaired <<< 7/18/2008 4:57:53 PM v0.914037/UNI 7/18/2008 4:57:53 PM CARD SERIAL: 000keaelite 7/18/2008 4:57:53 PM Loaded 51 flash de******ors 7/18/2008 4:59:34 PM TESTPOINT REPAIR STAGE #1 STARTED 7/18/2008 4:59:34 PM Open COM port OK 7/18/2008 4:59:39 PM ChipID:9900,EMP protocol:0301 7/18/2008 4:59:39 PM Speed:921600 7/18/2008 4:59:40 PM OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601599709 CERT:N/A 7/18/2008 4:59:40 PM FLASH CID:53 COLOR:RED 7/18/2008 4:59:41 PM LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 7/18/2008 4:59:41 PM PREPARING... 7/18/2008 4:59:49 PM ATTACH TP #1 AND PRESS "READY" 7/18/2008 5:00:19 PM RELEASE TP #1 AND PRESS "READY" 7/18/2008 5:00:20 PM TP #1 INCORRECT 7/18/2008 5:00:21 PM Elapsed: 47 secs. 7/18/2008 5:00:36 PM TESTPOINT REPAIR STAGE #1 STARTED 7/18/2008 5:00:36 PM Open COM port OK 7/18/2008 5:00:40 PM ChipID:9900,EMP protocol:0301 7/18/2008 5:00:40 PM Speed:921600 7/18/2008 5:00:41 PM OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601599709 CERT:N/A 7/18/2008 5:00:41 PM FLASH CID:53 COLOR:RED 7/18/2008 5:00:42 PM LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 7/18/2008 5:00:42 PM PREPARING... 7/18/2008 5:00:50 PM ATTACH TP #1 AND PRESS "READY" 7/18/2008 5:01:06 PM RELEASE TP #1 AND PRESS "READY" 7/18/2008 5:01:08 PM TP #1 LOOKS OKAY 7/18/2008 5:01:16 PM DONE 7/18/2008 5:01:16 PM Elapsed: 40 secs. 7/18/2008 5:02:45 PM TESTPOINT REPAIR STAGE #2 STARTED 7/18/2008 5:02:45 PM Open COM port OK 7/18/2008 5:02:50 PM ChipID:9900,EMP protocol:0301 7/18/2008 5:02:50 PM Speed:921600 7/18/2008 5:02:51 PM ATTACH TP #2 AND PRESS "READY" 7/18/2008 5:03:11 PM Trying to launch embedded bootloader... 7/18/2008 5:03:20 PM TP #2 INCORRECT OR STAGE #1 NOT EXECUTED 7/18/2008 5:03:20 PM PROCEDURE WAS STOPPED BY USER 7/18/2008 5:03:20 PM Elapsed: 35 secs. 7/18/2008 5:03:29 PM TESTPOINT REPAIR STAGE #2 STARTED 7/18/2008 5:03:29 PM Open COM port OK 7/18/2008 5:03:31 PM ChipID:9900,EMP protocol:0301 7/18/2008 5:03:31 PM Speed:921600 7/18/2008 5:03:31 PM ATTACH TP #2 AND PRESS "READY" 7/18/2008 5:03:46 PM Trying to launch embedded bootloader... 7/18/2008 5:04:29 PM TP #2 INCORRECT OR STAGE #1 NOT EXECUTED 7/18/2008 5:04:29 PM PROCEDURE WAS STOPPED BY USER 7/18/2008 5:04:29 PM Elapsed: 60 secs. 7/18/2008 5:04:36 PM TESTPOINT REPAIR STAGE #2 STARTED 7/18/2008 5:04:36 PM Open COM port OK 7/18/2008 5:04:44 PM ChipID:9900,EMP protocol:0301 7/18/2008 5:04:44 PM Speed:921600 7/18/2008 5:04:45 PM ATTACH TP #2 AND PRESS "READY" 7/18/2008 5:05:16 PM Trying to launch embedded bootloader... 7/18/2008 5:05:22 PM TP #2 INCORRECT OR STAGE #1 NOT EXECUTED 7/18/2008 5:05:23 PM PROCEDURE WAS STOPPED BY USER 7/18/2008 5:05:23 PM Elapsed: 46 secs. 7/18/2008 5:05:26 PM TESTPOINT REPAIR STAGE #2 STARTED 7/18/2008 5:05:26 PM Open COM port OK 7/18/2008 5:05:28 PM ChipID:9900,EMP protocol:0301 7/18/2008 5:05:28 PM Speed:921600 7/18/2008 5:05:29 PM ATTACH TP #2 AND PRESS "READY" 7/18/2008 5:05:49 PM Trying to launch embedded bootloader... 7/18/2008 5:05:49 PM TP #2 LOOKS OKAY 7/18/2008 5:05:49 PM RELEASE TP #2 AND PRESS "READY" 7/18/2008 5:05:52 PM INT LDRB2020_PRELOADER_FOR_SETOOL2 7/18/2008 5:05:55 PM WRITING EROM... 7/18/2008 5:05:58 PM DONE 7/18/2008 5:05:58 PM Elapsed: 32 secs. 7/18/2008 5:06:14 PM SIGNED MODE (USING SERVER). 7/18/2008 5:06:14 PM ALTERNATIVE SECURITY BYPASS ENABLED. 7/18/2008 5:06:14 PM Open COM port OK 7/18/2008 5:06:19 PM ChipID:9900,EMP protocol:0301 7/18/2008 5:06:19 PM Speed:921600 7/18/2008 5:06:20 PM Flash ID check:897E 7/18/2008 5:06:20 PM Flash props sent ok 7/18/2008 5:06:20 PM OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601599709 CERT:N/A 7/18/2008 5:06:20 PM FLASH CID:49 COLOR:BROWN 7/18/2008 5:06:21 PM 7/18/2008 5:06:21 PM Model:K800i 7/18/2008 5:06:21 PM MAPP CXC article: R8BF003 prgCXC1250210_GENERIC_WI 7/18/2008 5:06:21 PM MAPP CXC version: R8BF003 7/18/2008 5:06:21 PM Language Package:EUROPE_4 7/18/2008 5:06:21 PM CDA article: CDA102568/13 7/18/2008 5:06:21 PM CDA version: R6A 7/18/2008 5:06:21 PM Default article: cxc1250490 7/18/2008 5:06:21 PM Default version: R8BF003 7/18/2008 5:06:21 PM PROVIDER: 000-00 7/18/2008 5:06:21 PM SIMLOCKS NOT DETECTED 7/18/2008 5:06:21 PM 7/18/2008 5:06:21 PM RESTORATION FILE PRESENT FOR DETECTED FIRMWARE 7/18/2008 5:06:21 PM 7/18/2008 5:06:22 PM Elapsed: 7 secs. 7/18/2008 5:06:56 PM Open COM port OK 7/18/2008 5:07:01 PM ChipID:9900,EMP protocol:0301 7/18/2008 5:07:01 PM Speed:921600 7/18/2008 5:07:02 PM OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601599709 CERT:N/A 7/18/2008 5:07:02 PM FLASH CID:49 COLOR:BROWN 7/18/2008 5:07:04 PM LDR:060721 1021 DB2020_SERVICE_LOADER 7/18/2008 5:07:04 PM Flash ID check:897E 7/18/2008 5:07:04 PM Flash props sent ok 7/18/2008 5:07:04 PM writing E:\SETool\v.0914037\gdfs_in_ssw_format\db2020\db20 20gdfs_in_ssw_format_CID49_BROWN.ssw 7/18/2008 5:07:05 PM CURRENT FLASH FILE CID:49 7/18/2008 5:07:05 PM SSW uses complete hash, hash len is:640 7/18/2008 5:07:05 PM Will flash 32 blocks... 7/18/2008 5:07:39 PM SSW loading returns:0 7/18/2008 5:07:40 PM Setting up GDFS... 7/18/2008 5:07:40 PM OTP WRITE NOT EXECUTED. 7/18/2008 5:07:40 PM Writing simlocks... 7/18/2008 5:07:40 PM ALL UNLOCK/LOCK CODES SET TO "66358281" 7/18/2008 5:07:40 PM Signing... 7/18/2008 5:07:40 PM control keys complete. 7/18/2008 5:07:42 PM full sig complete. 7/18/2008 5:07:44 PM Elapsed: 48 secs. 7/18/2008 5:09:03 PM SIGNED MODE (USING SERVER). 7/18/2008 5:09:03 PM ALTERNATIVE SECURITY BYPASS ENABLED. 7/18/2008 5:09:03 PM Open COM port OK 7/18/2008 5:09:08 PM ChipID:9900,EMP protocol:0301 7/18/2008 5:09:08 PM Speed:921600 7/18/2008 5:09:09 PM Flash ID check:897E 7/18/2008 5:09:09 PM Flash props sent ok 7/18/2008 5:09:09 PM OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601599709 CERT:N/A 7/18/2008 5:09:09 PM FLASH CID:49 COLOR:BROWN 7/18/2008 5:09:10 PM 7/18/2008 5:09:10 PM Model:K610i 7/18/2008 5:09:10 PM Brand:Generic Trade TR 7/18/2008 5:09:10 PM MAPP CXC article: R1CB001 prgCXC1250374_GENERIC_TH 7/18/2008 5:09:10 PM MAPP CXC version: R1CB001 7/18/2008 5:09:10 PM Language Package:BALTIC 7/18/2008 5:09:10 PM CDA article: CDA102497/82 7/18/2008 5:09:10 PM CDA version: R5A 7/18/2008 5:09:10 PM Default article: cxc1250376 7/18/2008 5:09:10 PM Default version: R1CB001 7/18/2008 5:09:10 PM PROVIDER: 000-00 7/18/2008 5:09:10 PM SIMLOCKS NOT DETECTED 7/18/2008 5:09:10 PM 7/18/2008 5:09:10 PM RESTORATION FILE PRESENT FOR DETECTED FIRMWARE 7/18/2008 5:09:10 PM 7/18/2008 5:09:11 PM Elapsed: 7 secs. 7/18/2008 5:09:36 PM SIGNED MODE (USING SERVER). 7/18/2008 5:09:36 PM Open COM port OK 7/18/2008 5:09:39 PM ChipID:9900,EMP protocol:0301 7/18/2008 5:09:39 PM Speed:921600 7/18/2008 5:09:39 PM OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601599709 CERT:N/A 7/18/2008 5:09:39 PM FLASH CID:49 COLOR:BROWN 7/18/2008 5:09:41 PM LDR:060721 1021 DB2020_SERVICE_LOADER 7/18/2008 5:09:41 PM Flash ID check:897E 7/18/2008 5:09:41 PM Flash props sent ok 7/18/2008 5:09:41 PM writing E:\SETool\v.0914037\eroms\DB2020EROM_CNV_RED52_BRO WN_CID49_DB2020.ssw 7/18/2008 5:09:43 PM CURRENT FLASH FILE CID:49 7/18/2008 5:09:43 PM SSW uses complete hash, hash len is:40 7/18/2008 5:09:43 PM Will flash 2 blocks... 7/18/2008 5:09:45 PM SSW loading returns:0 7/18/2008 5:09:47 PM Elapsed: 11 secs. 7/18/2008 5:09:48 PM SIGNED MODE (USING SERVER). 7/18/2008 5:09:50 PM Open COM port OK 7/18/2008 5:09:53 PM ChipID:9900,EMP protocol:0301 7/18/2008 5:09:53 PM Speed:921600 7/18/2008 5:09:54 PM Flash ID check:897E 7/18/2008 5:09:54 PM Flash props sent ok 7/18/2008 5:09:54 PM OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601599709 CERT:N/A 7/18/2008 5:09:54 PM FLASH CID:52 COLOR:RED 7/18/2008 5:09:55 PM 7/18/2008 5:09:56 PM Model:K610i 7/18/2008 5:09:56 PM Brand:Generic Trade TR 7/18/2008 5:09:56 PM MAPP CXC article: R1CB001 prgCXC1250374_GENERIC_TH 7/18/2008 5:09:56 PM MAPP CXC version: R1CB001 7/18/2008 5:09:56 PM Language Package:BALTIC 7/18/2008 5:09:56 PM CDA article: CDA102497/82 7/18/2008 5:09:56 PM CDA version: R5A 7/18/2008 5:09:56 PM Default article: cxc1250376 7/18/2008 5:09:56 PM Default version: R1CB001 7/18/2008 5:09:56 PM PROVIDER: 000-00 7/18/2008 5:09:56 PM SIMLOCKS NOT DETECTED 7/18/2008 5:09:56 PM 7/18/2008 5:09:56 PM RESTORATION FILE PRESENT FOR DETECTED FIRMWARE 7/18/2008 5:09:56 PM 7/18/2008 5:09:56 PM BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE 7/18/2008 5:09:56 PM 7/18/2008 5:09:56 PM Elapsed: 7 secs. br keaelite |
>>> K550i gdfs damaged successfully repaired <<< | keaelite | SETool2 | 3 | 11-17-2008 23:05 |
>>> K610i damaged GDFS successfully repaired <<< | keaelite | SETool2 | 19 | 10-08-2008 09:01 |
Go to first new post >>> K550i gdfs damaged successfully repaired <<< | ayhen42 | SETool2 | 1 | 08-06-2008 10:06 |
>>> again again again another S500i GDFS damaged repaired success <<< | keaelite | SETool2 | 0 | 07-14-2008 11:07 |
can i change flash ic from one k800i to another?-reason gdfs damaged | zonetrichur | Sony Ericsson | 0 | 10-13-2007 11:11 |
