12-17-2009, 15:21 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | DB2020 GDFS repair failed..NAK error in GDFS writing! I just got a K550i with red blinking....GDFS damaged!.....So i try to repair it via recovery button....Phone succesfully gone to developer state...But when i try to write GDFS the software shows error NAK.....Here is log! Code: SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489301800958 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:2019 writing "E:\Box Softwares\setool\v0.915053\gdfs_in_ssw_format\db2020\k550_gdfs_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... subblock 000 NAK, [47E00000/00010000] Elapsed: 10 secs. |
12-19-2009, 10:09 | #3 (permalink) |
No Life Poster Join Date: Jan 2008 Location: .::AZAD KASHMIR::.
Member: 681574 Status: Offline Sonork: 100.1614243 Thanks Meter: 138 | I HAVE SAME PROBLEM W610 CID 52 HERE IS LOGS SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID:2019 GOT SEED:0E23090023804E6A15C09306 P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401026940 CERT:N/A PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 8 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401026940 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:2019 writing "F:\New Folder\gdfs_in_ssw_format\db2020\W610_GDFS_SSW.ssw " CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... verify block error 68/01, [47E10000/00010000] Elapsed: 14 secs. |
04-06-2010, 15:31 | #5 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 478737 Status: Offline Sonork: 100.1648965 Thanks Meter: 4 | w610 my loge v0.915057/UNI CARD SERIAL: 00025056 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID:2019 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A FLASH CID:52 COLOR:RED SCRC READ FAILURE Elapsed: 9 secs. SIGNED MODE (USING SERVER) CFG:110000000000 bad username/password. CARD COUNTERS: FLASH 1348, UNLOCK 264 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:110000000000 SERVER CREDITS LEFT/USED: 15/15 CARD COUNTERS: FLASH 1348, UNLOCK 264 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID:2019 GOT SEED:E0C0676923804E6A15E0A073 P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 13 secs. SIGNED MODE (USING SERVER) CFG:100000000000 SERVER CREDITS LEFT/USED: 14/16 CARD COUNTERS: FLASH 1348, UNLOCK 264 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID:2019 GOT SEED:057672FA23804E6A15E0A073 P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 10 secs. SIGNED MODE (USING SERVER) CFG:100000000000 SERVER CREDITS LEFT/USED: 14/16 CARD COUNTERS: FLASH 1348, UNLOCK 264 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:2019 writing "E:\SE TOOL\v0.915057\gdfs_in_ssw_format\db2020\W610_GDFS _SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... subblock 000 NAK, [47E10000/00010000] Elapsed: 6 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:2019 writing "E:\SE TOOL\v0.915057\gdfs_in_ssw_format\db2020\W610_GDFS _SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... subblock 000 NAK, [47E00000/00010000] Elapsed: 6 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:2019 writing "E:\SE TOOL\v0.915057\gdfs_in_ssw_format\db2020\W610_GDFS _SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... subblock 000 NAK, [47E00000/00010000] Elapsed: 7 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID:2019 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A FLASH CID:49 COLOR:BROWN PROCEDURE WAS STOPPED BY USER can't get packet start. no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 18 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:2019 writing "E:\SE TOOL\v0.915057\gdfs_in_ssw_format\db2020\W610_GDFS _SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... subblock 000 NAK, [47E00000/00010000] Elapsed: 17 secs. CFG:000000000000 DB2020 EROM UPGRADE MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A FLASH CID:49 COLOR:BROWN ldr_on_ldr hdr no ack (10) FAILED TO LOAD EROM UPGRADE LOADER Elapsed: 4 secs. CFG:000000000000 DB2020 EROM UPGRADE MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A FLASH CID:49 COLOR:BROWN ldr_on_ldr hdr no ack (10) FAILED TO LOAD EROM UPGRADE LOADER Elapsed: 4 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:2019 writing "E:\SE TOOL\v0.915057\gdfs_in_ssw_format\db2020\W610_GDFS _SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... subblock 000 NAK, [47E10000/00010000] Elapsed: 8 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:2019 writing "E:\SE TOOL\v0.915057\gdfs_in_ssw_format\db2020\W610_GDFS _SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... subblock 000 NAK, [47E00000/00010000] Elapsed: 7 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:2019 writing "E:\SE TOOL\v0.915057\eroms\db2020\DB2020EROM_CNV_RED52_B ROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED gdfsWrite err:000E SCRC WRITE FAILURE FINALIZATION FAILED. Elapsed: 8 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:2019 writing "E:\SE TOOL\v0.915057\gdfs_in_ssw_format\db2020\W610_GDFS _SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 HDR block not accepted,error: 19 Elapsed: 17 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID:2019 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A FLASH CID:52 COLOR:RED PROCEDURE WAS STOPPED BY USER can't get packet start. setGDFS_params failed failed to setup GDFS Elapsed: 22 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A FLASH CID:52 COLOR:RED phone CID not supported in that mode Elapsed: 6 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:2019 writing "E:\SE TOOL\v0.915057\gdfs_in_ssw_format\db2020\W610_GDFS _SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 HDR block not accepted,error: 19 Elapsed: 11 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:2019 writing "E:\SE TOOL\v0.915057\gdfs_in_ssw_format\db2020\W610_GDFS _SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 HDR block not accepted,error: 19 Elapsed: 12 secs. |
06-16-2010, 12:47 | #7 (permalink) |
No Life Poster Join Date: Sep 2007 Location: algeria
Member: 591880 Status: Offline Thanks Meter: 561 | Code: subblock 000 NAK, [47E10000/00010000] Code: CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35489401473614 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:2019 writing "E:\SE TOOL\v0.915057\gdfs_in_ssw_format\db2020\W610_GDFS _SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 HDR block not accepted,error: 19 |
T919 error in FS write. | Celhack | NSPRO | 19 | 12-11-2009 02:10 |
error in gdfs repair se k770i cid52 | yarra | Sony Ericsson Hardware Repair | 4 | 07-01-2009 10:14 |
w8500i&K610i gdfs repair failed but credits gone | buffer | D-Unlock Suite | 7 | 04-22-2009 14:58 |
w850 gdf repair fail. and supreme credit gone. | alhajikoroma | D-Unlock Suite | 6 | 02-17-2009 21:44 |
w580i gdfs repair failed but credits gone | maximas007 | D-Unlock Suite | 2 | 01-26-2009 19:13 |
