01-08-2012, 08:19 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | E51i xperia unlock failed, 2 credits lost RUNNING v 1.1203/01.14/UNI CARD SERIAL 00092xxxx USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 llbug:read error: "The parameter is incorrect" CAN'T LOAD IDENTIFICATION LOADER. Elapsed: 47 secs. CFG:000000000000 llbug:read error: "The parameter is incorrect" CAN'T LOAD IDENTIFICATION LOADER. Elapsed: 39 secs. CFG:000000000000 PROCEDURE WAS STOPPED BY USER CAN'T LOAD IDENTIFICATION LOADER. Elapsed: 18 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_EROM VER "R8A029" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 FLASH ID: "002C/00BC" LOADER VERSION: "R4A060" PHONE IMEI : 3584520xxxxxxxxx Checking for signature ... signature found, skipping calculation REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEB***ING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP ... failed, err: [00000002] Unlock FAILED Elapsed: 17 secs. |
01-08-2012, 21:25 | #3 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Morocco
Member: 136492 Status: Offline Thanks Meter: 289 | for this phone the signature is already calculated ( once for ever), just disable your antivirus, check setting / applications / usb debbug, restart your PC and try again. Some times you have to uninstall the antivirus. If ever you give back the phone to his custumer without unlocking = you give a gift to another unlocker ( using Setool of corse). good luck Brother. |
