error w200 help please v0.914029/UNI CARD SERIAL: ******xx Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:8040,EMP protocol:0301 NEW SECURITY MODEL DETECTED erom_readvar: error reading unit 1/725 error while reading SIMLOCK SIGNATURE unit phone was tampered with other software SECURITY UNITS CAN'T BE READ ! DAMAGED FIRMWARE,GDFS OR EMPTY PHONE phone pre-boot failed,possible RECOVERY needed. Elapsed: 125 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:8040,EMP protocol:0301 NEW SECURITY MODEL DETECTED erom_readvar: error reading unit 1/725 error while reading SIMLOCK SIGNATURE unit phone was tampered with other software SECURITY UNITS CAN'T BE READ ! DAMAGED FIRMWARE,GDFS OR EMPTY PHONE phone pre-boot failed,possible RECOVERY needed. Elapsed: 10 secs. waths is error please |
same w200 cid 49 problem help me |
during their famous method of "testpoint bypass", they writing patched erom with own custom loader embedded, patching simlock signature check and ... erasing simlock signature without any reason, which prevents setool2 from making backup. fix is extremly simple: using com/ufs write next script in SIGNED MODE (check ONLY "USE SIGNED MODE" on settings) for db2020: Code: gdfswrite:0001085144554D4D5944415441 Code: gdfswrite:0001072544554D4D5944415441 |
2 Attachment(s) here is file to repair the fone temperd by dreambox. Repair DB testpoint-DB2012: Repair DB testpoint-DB2020: |
