05-09-2008, 18:20 | #1 (permalink) |
Crazy Poster Join Date: May 2006
Member: 270008 Status: Offline Thanks Meter: 2 | error w200 help please CARD SERIAL: ******xx Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:8040,EMP protocol:0301 NEW SECURITY MODEL DETECTED erom_readvar: error reading unit 1/725 error while reading SIMLOCK SIGNATURE unit phone was tampered with other software SECURITY UNITS CAN'T BE READ ! DAMAGED FIRMWARE,GDFS OR EMPTY PHONE phone pre-boot failed,possible RECOVERY needed. Elapsed: 125 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:8040,EMP protocol:0301 NEW SECURITY MODEL DETECTED erom_readvar: error reading unit 1/725 error while reading SIMLOCK SIGNATURE unit phone was tampered with other software SECURITY UNITS CAN'T BE READ ! DAMAGED FIRMWARE,GDFS OR EMPTY PHONE phone pre-boot failed,possible RECOVERY needed. Elapsed: 10 secs. waths is error please |
06-21-2008, 13:40 | #3 (permalink) |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | that phone is tampered by d_reambox software. during their famous method of "testpoint bypass", they writing patched erom with own custom loader embedded, patching simlock signature check and ... erasing simlock signature without any reason, which prevents setool2 from making backup. fix is extremly simple: using com/ufs write next script in SIGNED MODE (check ONLY "USE SIGNED MODE" on settings) for db2020: Code: gdfswrite:0001085144554D4D5944415441 Code: gdfswrite:0001072544554D4D5944415441 |
The Following User Says Thank You to NADEEM GONDAL For This Useful Post: |
06-22-2008, 05:22 | #4 (permalink) |
Member: 575900 Status: Offline Thanks Meter: 3,177 | here is file to repair the fone temperd by dreambox. Repair DB testpoint-DB2012: Repair DB testpoint-DB2020: |
The Following 2 Users Say Thank You to NADEEM GONDAL For This Useful Post: |
N70--rm 99 product mismatch error somebody help please | rimboy_cbe | HWK | 11 | 11-26-2009 15:58 |
SEARCHING FOR MICRO-BOX: error 9999 help please | samirtelecom | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 3 | 02-24-2009 16:30 |
UST2 V708 V707II Error ( HELP PLEASE | SlavaKis | UST Pro II | 11 | 10-28-2007 14:54 |
k750i error 000403!!! help please | mmanduri | SonyEricsson (USB-Smart) | 0 | 07-18-2006 12:10 |
6100 flashing error 44449100 help please... | mmanduri | Nokia Hardware & Hardware Repair | 7 | 08-25-2004 08:12 |
