07-29-2007, 23:02 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Into the Unknown
Member: 121461 Status: Offline Thanks Meter: 49 | Help unlocking K800 with SETOOL SERVER SUPPORT ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35170701610068 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok CSloader version: 070125 1328 GENCXC1250562_DB2020_CSLOADER_R3A006 loader startup: executed loader filesystem startup: executed loader GDFS startup: executed Connecting to server No server found. failed, that is fatal Elapsed:42 secs. then i realized that i didnt check the "alternative security bypass" so i did and tried again and got this: SERVER SUPPORT ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35170701610068 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok phone CID not supported in that mode... patience... Elapsed:1 secs. SERVER SUPPORT ENABLED. No server found. CARD COUNTERS: FLASH 4, UNLOCK 26 Elapsed:23 secs. so i am now asking the experts to please advise me on what my next steps are. best regards |
07-29-2007, 23:12 | #3 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
ur phone is cid 52 sir. so u cant unlock it.. FLASH CID:52 COLOR:RED u can use davinci or ub... | |
07-31-2007, 14:19 | #6 (permalink) |
Member: 121461 Status: Offline Thanks Meter: 49 | Ok guys server is back online!! v0.91380093/UNI Card serial:00***** Loaded 51 flash descriptors SERVER SUPPORT ENABLED. SERVER CREDITS LEFT/USED: 30/0 CARD COUNTERS: FLASH 4, UNLOCK 26 Elapsed:4 secs. SERVER SUPPORT ENABLED. ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35170701610068 CERT:RED FLASH CID:52 COLOR:RED MAPP CXC article: R1KG001 prgCXC1250568_HUTCHISON_WI MAPP CXC version: R1KG001 Language Package:HUTCH_1 CDA article: CDA102511/69 CDA version: R14A Default article: cxc1250490 Default version: R1KG001 Network LOCKED Operator: MULTIPLE RESTORATION FILE NOT PRESENT "R1KG001_CXC1250568_HUTCHISON_WI" YOU MUST PERFORM FULL FLASHING FOR PATCH UNLOCK |
07-31-2007, 22:04 | #8 (permalink) | |
Freak Poster Join Date: Aug 2004
Member: 77779 Status: Offline Thanks Meter: 4 | Quote:
After that try again. | |
07-31-2007, 22:56 | #9 (permalink) |
Banned Join Date: May 2003 Location: www.CentralMobile.net/vbb
Member: 28188 Status: Offline Thanks Meter: 579 | Hi @Teufel Rest for what. This phone is CID52 and can't be unlocked by setool for now. @Linkz go to www.setool.net forum, you need 1 To read Faq 2 To read news or something like 3 To download the manual Best regards, Aishur |
w580i still unlock problem with setool plzzzz help | hajukhan | SETool2 | 11 | 03-01-2009 16:44 |
help for unlock w200i with setool box | samirtelecom | Sony Ericsson | 3 | 02-12-2009 15:06 |
help me to unlock w200 with setool | gagan_o5 | SETool2 | 2 | 12-14-2008 12:05 |
How to save the complete flash of K800 with setool 3 | tycfung | Sony Ericsson | 3 | 02-29-2008 21:10 |
need help for unlock v630i with setool | SLIPLOCK | Sony Ericsson | 4 | 06-04-2007 16:16 |
