11-27-2007, 16:59 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: USULUTAN, EL SALVADOR. Age: 47
Member: 545374 Status: Offline Thanks Meter: 34 | how to upgrade cid 51 to cid52 how do i do that?? br juvenile |
11-27-2007, 17:07 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | @juvenl 1=select script cid 51to 52 from setool folder 2=write script 3=after finish write ur phone is done to cid 52 thanks |
11-27-2007, 17:17 | #3 (permalink) |
Member: 545374 Status: Offline Thanks Meter: 34 | what i am doing wrong?? ok this is the log v0.914014/UNI Card serial:000***** Loaded 51 flash descriptors ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:51 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:3560********** CERT:RED FLASH CID:51 COLOR:RED Model:K550i MAPP CXC article: R1JD001 prgCXC1250669_GENERIC_LI MAPP CXC version: R1JD001 Language Package:AMERICA_2 CDA article: CDA102743/141 CDA version: R1A Default article: cxc1250671 Default version: R1JD001 Network LOCKED Operator: MULTIPLE RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed:8 secs. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:51 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:3560********** CERT:RED FLASH CID:51 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok phone CID not supported in that mode Elapsed:11 secs. br juvenile |
11-27-2007, 18:43 | #5 (permalink) |
Member: 545374 Status: Offline Thanks Meter: 34 | now yes, but this is the new log and nothing happened. v0.914014/UNI Card serial:00047812 Loaded 51 flash descriptorsSERVER SUPPORT ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:51 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35601901035060 CERT:RED FLASH CID:51 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok LDR:070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed Will execute script now. Writing GDFS var 0001:084E len:010B Success Phone detached Elapsed:24 secs. SERVER SUPPORT ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:51 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:3560*********** CERT:RED FLASH CID:51 COLOR:RED Model:K550i MAPP CXC article: R1JD001 prgCXC1250669_GENERIC_LI MAPP CXC version: R1JD001 Language Package:AMERICA_2 CDA article: CDA102743/141 CDA version: R1A Default article: cxc1250671 Default version: R1JD001 Network LOCKED Operator: MULTIPLE RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed:6 secs. SERVER SUPPORT ENABLED. ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:51 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:3560********** CERT:RED FLASH CID:51 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok bypassing DB2020 security... bad username/password. unlock failed, that is fatal Elapsed:11 secs. so whats the problem now br juvenile |
11-27-2007, 18:53 | #6 (permalink) | |
Junior Member Join Date: Sep 2006
Member: 358863 Status: Offline Thanks Meter: 2 | untick do full unlock instead of usercode edit Quote:
11-27-2007, 19:08 | #8 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Little apt called Alhambra
Member: 13748 Status: Offline Thanks Meter: 84 | STOP SPAMMING BOARD WITH QUESTIONS ALLREADY ASNWERED. To upgrade any CID to CID52 use Sonyericsson Update software, you can download here: http://www.sonyericsson.com/cws/down...2.7.9.14-1.exe Just select your model press next and connect when soft ask. Best regards. |
11-27-2007, 19:34 | #9 (permalink) | |
Member: 545374 Status: Offline Thanks Meter: 34 | Quote:
br juvenile | |
11-28-2007, 16:58 | #10 (permalink) | |
Freak Poster Join Date: Nov 2005 Location: Colombia Age: 48
Member: 197360 Status: Offline Thanks Meter: 25 | not for all Quote:
that original soft from sony ericsson don't work at all, i've tried pcs w710 cid 49 and after a lot of time says, not upgrade needed, if you have setool or universal box or other you can upgrade cid in a profesional way | |
I NEED FLASH FILE MAIN W300i CID 51 AND CID52 | siscel | Cruiser Suite | 9 | 04-26-2010 08:18 |
how to convert w880 cid 51 to 52 | sharbel | Cruiser Suite | 5 | 07-12-2008 11:10 |
How can I change CID 51 to CID 52 (SE K800i) with Cruiser? | Fregh | Sony Ericsson | 3 | 05-08-2008 23:03 |
how upgrade cid 50 to cid 52 for w810 | magic2300 | Sony Ericsson | 5 | 12-11-2007 16:13 |
How To Change W880i Cid 51 To 52 With Cruiser (06) | Shoja | Cruiser Suite | 2 | 06-15-2007 16:49 |
