Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 02-23-2009, 18:22   #1 (permalink)
F@RUK S's Avatar
Member: 51153
Sonork: 100.113241
Thanks Meter: 3,682
LG KF750 not supported at the moment any solution ?
Any solution to unlock this LG KF750 ?
i try with last vesrsion with setool.
SIGNED MODE (USING SERVER)
ChipID:C900,EMP protocol:0401
BOOTROM MODE DETECTED
OTP LOCKED:1 CID:54 PAF:1 IMEI:353*********** CERT:BROWN
Elapsed: 5 secs.
Old 02-23-2009, 18:53   #2 (permalink)
fadhel's Avatar
Member: 39196
Thanks Meter: 126
not see to that message.
you can do it .try and post result plz.
The Following User Says Thank You to fadhel For This Useful Post:
Old 02-23-2009, 19:01   #3 (permalink)
mamepap's Avatar
Member: 532853
Thanks Meter: 610
if you trying identify, you will always get same result.
press unlock and all will be ok
The Following User Says Thank You to mamepap For This Useful Post:
Old 02-24-2009, 10:13   #4 (permalink)
F@RUK S's Avatar
Member: 51153
Sonork: 100.113241
Thanks Meter: 3,682
Unlock DONE.
LDR:080610 0757 YTRCXC1721610_A2_DB31XX_PRODUCTION_LOADER_ACC_SDRA M_P6F
LDR CAPS:SYSTEM SIGNATURE
LDR:080610 0759 YTRCXC1724028_1A2_DB31XX_PRODUCTION_LOADER_APP_SDR AM_CABS_JEFF_P6F
LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM
WRITING CLEAR SIMLOCK UNITS...
ALL UNLOCK/LOCK CODES SET TO "74480650"
phone detached
Elapsed: 41 secs.
Old 02-24-2009, 11:36   #5 (permalink)
sniper007's Avatar
Member: 722656
Sonork: 100.1584918
Thanks Meter: 294
yes for LG KF750 always just click unlock/repair. do not i identify it!!!!!!
Old 02-24-2009, 15:51   #6 (permalink)
celcomputo2007's Avatar
Member: 576154
Thanks Meter: 23
friends with cable which connects the LG? thanks
Old 02-24-2009, 16:27   #7 (permalink)
F@RUK S's Avatar
Member: 51153
Sonork: 100.113241
Thanks Meter: 3,682
A2 USB Cable from KU580
not supported at the moment lg kt 520 kakaomar SETool2 1 08-11-2009 11:07
DCT4Plus service is not available at the moment ... Any Update?? airos_8 Universalbox 1 06-23-2008 11:44
CSCA service is not availble at the moment nofear197979 Universalbox 0 09-30-2007 23:48
Terminated with error: CSCA service is not available at the moment [00001212] alunecosu_hd Universalbox 5 09-01-2007 16:32
CSCA service is not available at the moment globalmedia100 Universalbox 4 07-17-2007 08:57
Page generated in 0.18771 seconds with 9 queries
