07-21-2008, 13:54 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Pak Age: 45
Member: 162328 Status: Offline Sonork: 100.1618216 Thanks Meter: 21 | K310 CID49 please wait help urgent iv0.914037/UNI CARD SERIAL: ******x Loaded 51 flash descriptors Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Can't load ID loader ! Elapsed: 86 secs. RECOVERY MODE STARTED Open COM port OK REC:070307 0947 NPA4_CXC1326739_DB2010_SEMC_RECOVERY_P2A Fetching phone data from OTP OTP LOCKED:1 CID:49 PAF:1 IMEI:35603501710784 CERT:RED THAT WILL KILL YOUR PHONE, ABORTED Elapsed: 2 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35603501710784 CERT:RED ldr_on_ldr hdr no ack (10) Elapsed: 3 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 phone pre-boot failed,possible RECOVERY needed. Elapsed: 53 secs. RECOVERY MODE STARTED Open COM port OK REC:070307 0947 NPA4_CXC1326739_DB2010_SEMC_RECOVERY_P2A Fetching phone data from OTP OTP LOCKED:1 CID:49 PAF:1 IMEI:35603501710784 CERT:RED THAT WILL KILL YOUR PHONE, ABORTED Elapsed: 1 secs. Processing script "C:\Documents and Settings\Sharry\Desktop\k310_gdfs_in_ssw_format.ss w"... Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35603501710784 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 HDR block not accepted,error:AA prepare failed,that is FATAL Elapsed: 18 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35603501710784 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK Trying to launch embedded bootloader... embedded bootloader not responds ! PROCEDURE WAS STOPPED BY USER Elapsed: 79 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35603501710784 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 ldr_on_ldr hdr no ack (10) Elapsed: 7 secs. Open COM port OK phone pre-boot failed,possible RECOVERY needed. PROCEDURE WAS STOPPED BY USER Elapsed: 2 secs. Open COM port OK phone pre-boot failed,possible RECOVERY needed. PROCEDURE WAS STOPPED BY USER Elapsed: 6 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35603501710784 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK Trying to launch embedded bootloader... embedded bootloader not responds ! PROCEDURE WAS STOPPED BY USER Elapsed: 208 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 phone pre-boot failed,possible RECOVERY needed. Elapsed: 41 secs. RECOVERY MODE STARTED Open COM port OK REC:070307 0947 NPA4_CXC1326739_DB2010_SEMC_RECOVERY_P2A Fetching phone data from OTP OTP LOCKED:1 CID:49 PAF:1 IMEI:35603501710784 CERT:RED THAT WILL KILL YOUR PHONE, ABORTED Elapsed: 1 secs. |
07-21-2008, 15:43 | #4 (permalink) |
Member: 162328 Status: Offline Sonork: 100.1618216 Thanks Meter: 21 | Phone is dead now if some one have rest file R4DA043_CXC1250466_GENERIC_DO plz upload soon here is log cant flash other file fail to flash error PHONE IS RED RETAIL PRODUCT FLASH CID detected49 Speed921600 OTP LOCKED1 CID49 PAF1 IMEI35603501710784 CERTRED PATCH061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 ldr_on_ldr hdr no ack (10) Elapsed 4 secs. here is full log Open COM port OK ChipID8040,EMP protocol0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected49 Speed921600 Flash ID check897E Flash props sent ok OTP LOCKED1 CID49 PAF1 IMEI35603501710784 CERTRED phoneID error (1) Error during phone id. Elapsed 16 secs. Open COM port OK ChipID8040,EMP protocol0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected49 Speed921600 Flash ID check897E Flash props sent ok OTP LOCKED1 CID49 PAF1 IMEI35603501710784 CERTRED FLASH CID49 COLORRED ModelK310i MAPP CXC article R4DA043 prgCXC1250466_GENERIC_DO MAPP CXC version R4DA043 Language PackageM_EAST_N_AFR CDA article CDA1025766 CDA version R2A Default article cxc1250474 Default version R4DA043 PROVIDER 000-00 SIMLOCKS NOT DETECTED USERCODE0000 RESTORATION FILE NOT PRESENT R4DA043_CXC1250466_GENERIC_DO YOU MUST PERFORM FULL FLASHING WHEN ALTERNATIVE SECURITY BYPASS ENABLED Elapsed 3 secs. Open COM port OK ChipID8040,EMP protocol0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected49 Speed921600 OTP LOCKED1 CID49 PAF1 IMEI35603501710784 CERTRED PATCH061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 ldr_on_ldr hdr no ack (10) Elapsed 4 secs. Open COM port OK ChipID8040,EMP protocol0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected49 Speed921600 err 0 (0) loader payload not accepted phone pre-boot failed,possible RECOVERY needed. Elapsed 9 secs. Open COM port OK ChipID8040,EMP protocol0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected49 Speed921600 OTP LOCKED1 CID49 PAF1 IMEI35603501710784 CERTRED PATCH061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS READY Open COM port OK Trying to launch embedded bootloader... INT LDRCOMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 Flash ID check897E Flash props sent ok FOUND R4DA043_CXC1250466_GENERIC_DO Restore fromR4DA043_CXC1250466_GENERIC_DO can't open file KSe Tool3v0.914037restR4DA043_CXC1250466_GENERIC_DO Setting up GDFS... Writing simlocks... ALL UNLOCKLOCK CODES SET TO 33100743 Signing... control keys complete. full sig complete. Unlock DONE Elapsed 49 secs. |
07-21-2008, 16:27 | #5 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Pakistan Age: 36
Member: 300354 Status: Offline Sonork: 100.1577485 Thanks Meter: 760 | Q: What will happend if i don,t have Rest File? A: Don,t worry you can make Rest Files by Yourself.. How: 1: Select then Main File in Flash Tab. (Must be Same as Rest,s Name) 2: Click on Identify and Connect phone via Cable.. 3: Wait Few Seconds.. Yuppi You have Rest file created By yourself..! |
K608 CID49 Please wait!!! HELP | sovservice | Sony Ericsson | 6 | 03-27-2009 19:17 |
k310 on please wait! | msashami | SETool2 | 3 | 01-18-2009 17:11 |
k750i cid49 please wait | chandmobiles@gm | Cruiser Suite | 17 | 07-16-2008 10:38 |
K750i Cid49 Please Wait | mmcr | Sony Ericsson | 4 | 09-13-2006 17:53 |
k750i cid49 please wait - repair dont work | hasi | SonyEricsson (USB-Smart) | 20 | 07-24-2006 08:59 |
