06-15-2008, 02:13 | #2 (permalink) |
Banned Join Date: May 2006 Location: United Kingdom
Member: 270521 Status: Offline Sonork: 100.15962233 Thanks Meter: 369 | in settings tab click signed mode and do full unlock instead of security code and press unlock and it takes 4 logs BR Shery |
The Following User Says Thank You to faisal_sherry For This Useful Post: |
06-15-2008, 05:05 | #3 (permalink) |
Banned Join Date: Jul 2004 Age: 46
Member: 74464 Status: Offline Thanks Meter: 17 | sol. # 1. restore back-up. 1. select in "misc. edit" file %setool%\backup\%imei%_%datetime%.fixup 2. execute "write script". 3. if successfuly writing the back-up unlock it again . sol. # 2. Do full unlock. full unlock: 4 logs 1. download latest rest file 2. on settings check " USE SEVER FOR CSCA UNLOCK/FLASH" & "DO FULL UNLOCK INSTEAD OF USERCODE EDIT" fill up valid username & password. 3. back to sony ericsson tab then press unlock. |
The Following User Says Thank You to teknotelgsm For This Useful Post: |
06-15-2008, 05:30 | #4 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: lets See.
Member: 128918 Status: Offline Thanks Meter: 282 | u r right except mark text Quote:
@movicelular follow his post 1st part if u closed all locks by mistake wtever. if u get it all locks closed then it need 4 creits and follow faisal steps. | |
The Following User Says Thank You to Afzaal For This Useful Post: |
06-15-2008, 06:42 | #5 (permalink) |
Banned Join Date: Apr 2008 Location: R.V.Q. Productions
Member: 741807 Status: Offline Thanks Meter: 9 | if you have credits its very easy if you dont have try this solution, Tick SIGN MODE 1. select in "misc. edit" file 2. setool\backup\imei_datetime.fixup 3. execute "write script". 4. if successfuly writing the back-up unlock it again, if it's still all closed, do step no. 2 put on misc folder.-- setool\backup\imei_datetime._PM.seczone if successfuly writing the back-up unlock it again |
The Following User Says Thank You to Dolphy For This Useful Post: |
w810i CID 50 RED: network lock all zero | darkpk69 | Sony Ericsson | 1 | 09-03-2008 06:58 |
errors on k310i cid 50 | Lupin D'3rd | Universalbox | 0 | 11-26-2007 01:06 |
K310i cid 50, K510i cid 50 ?????????? | afo | Cruiser Suite | 1 | 11-18-2007 17:46 |
TAC LIST FOR K310i CID 50 | CONG YANG | HWK | 0 | 11-14-2007 11:58 |
K310i CID 50 PROBLEM | Panthereitor | Cruiser Suite | 3 | 11-10-2007 05:16 |
